MAIN ENGINE FAN
MAIN ENGINE FAN
Hello, I just notice that my main engine fans (2 fans behind the radiator) are not running when I start the car and after..but it will start when I hit the "A/C" button...is it suppose to do that or the fans must run while the engine' running? if so, how do I fix this problem? I check all the inside fuses..all works as normal..is there a sensor relay for the main engine fans located somewhere? the engine seem a little hotter when I pop up the hood..thanks
ThePuf
06-05-2007 10:56 AM
We need to develop a mod to run the AC fan for a few minutes after engine shutdown to lower engine..
jetboy737
08-07-2000 04:38 PM
