Need some trouble shooting help
Well my check engine light came on with the following codes.
17509 O2 Sensor Circ., Bank 1 - Sensor 1 Voltage too Low/Air Leak
17514 O2 Sensor Circ.,Bank 2 - Sensor 1 Voltage too Low/Air Leak
I changed both sensors and still getting the code. What else could it be. The sensores are universal type with white red and black wire.
You might spray carb cleaner around the intake manifold w/ engine running
Anywhere that you've sprayed, which results in a change in idle, will be the location of a vacuum leak.
Also, if you have a car air injection, make sure the plastic pipes aren't cracked or broken.
Re: You might spray carb cleaner around the intake manifold w/ engine running
Is there a place that is most likely the cause? I found the hose by the fpr was about to give so it's changed but the code is still in there. I've read that some people have problems with universal O2's. is this a likely culprit? I never took anything apart on this car that would cause an air leak. so basically it comes down to broken vacum hoses or O2's.
Re: spray individual areas one at a time and see what happens.
No leak anywhere. Replaced all hoses with new ones. Now I'm getting the heater circuit code for both front O2's. I think these universals are junk. Never had these codes or problems before. Is there a way to check these junk sensors?
RedDragoN750
Audi 100 / A6 (C4 Platform)
11-06-2008 07:27 PM
