What is this?? 1992 audi 100 cs quattro
Old 03-29-2015, 03:36 PM
zackanderson01's Avatar
Default What is this?? 1992 audi 100 cs quattro
if i cover it with my finger the motor stalls. 1992 audi 100 cs quattro 2.8l. crankshaft breather hose
Old 03-29-2015, 05:10 PM
varia's Avatar
its a plug
Old 03-29-2015, 05:14 PM
Originally Posted by varia
its a plug
then why does it stall when pluged? is it a port for a air meter or something?
Old 03-30-2015, 07:14 AM
ncoupe's Avatar
The line is part of the brake servo vacuum circuit. At least one section of it is made out of hard plastic, which I broke when I took off the intake manifold to replace the gaskets on the top end and the oil pressure valves. I had to patch it up, because you cannot find a replacement. In the next few weeks, I will replace the valve cover gaskets, and then I will do the experiment you did and see whether my '92 stalls as well.
Old 04-01-2015, 08:49 AM
The problem I'm having is the motor sounds starved at idle. Give it a little gas she sounds great but chugs and supters at idle. I was thinking the idle air, but if I unplug and start, the idle rises bit still chugging and returns when plugged in. If I unplug while running Nothing seems to happen.
Old 04-01-2015, 06:20 PM
Rusty Spokes's Avatar
Could be some adaptive memory in your ECU..you been running with an air leak.
Cap the leak. Disconnect the battery. Go have a beer. Reconnect the battery and reset you clock and radio.
Go drive the car for a while. See what happens.
Old 04-04-2015, 11:49 AM
plugged hole, disconnected battery, rest clock and radio. running much much better
Old 04-08-2015, 06:34 AM
It should improve the more you drive.
Old 04-08-2015, 01:25 PM
Its actually came back a little bit, im thinking 02 sensor, also lots of white smoke on throttle.
sandorck
03-26-2017 10:45 AM
hubturn
11-25-2010 07:55 AM
kandrews1
Audi 100 / A6 (C4 Platform)
05-23-2010 10:49 PM
Riley's A4
30v V6 Discussion
04-09-2007 05:08 PM
Avery Ironside
Misc. Models Discussion
02-10-2000 03:05 PM
Quick Reply: What is this?? 1992 audi 100 cs quattro
