Wheel bearing tools
I would like to buy wheel bearing tool at Harbor Freight. Which part number should I tell them ? Thanks
Re: Wheel bearing tools
<center><img src="http://home.ec.rr.com/miktip/wheelbear.jpg"></center><p>I have 2 hydraulic presses, from HF, that I use to R&R Audi wheel bearings. Plus the Schaley tool pictured above! ;O)
What is it your wanting from HF? |
I really just want enough tools to remove my wheel bearings, and future Audi's wheel bearings.
Re: Well............
Your gonna need most that are pictured.
Audi wheel bearings are better "pressed" in & out of their housings. So you should get a hydraulic press. Then your gonna need a couple special tools to aid the press with the bearings. |
I've always found the old bearing to be a remakably good fit
Usually a bit of ingenuity will cope with almost any repair. How many self employed mechanics go around with a load of special tools just for the one occasion the get asked to do the one they do not have the tool for?
I think you may find it possible with an ordinary vice and a drift or some kind, as Duncan says, old bearings are a great fit. |
