Keep blowing relays
Keep blowing relays
I can not use my heater window wipers roll up Windows and radiator fan no work I have replace relays still no work could the stock ground wires be bad
Astro, are you really blowing out the relays ie the power items work for an instant and quit? Are you sure the relay you replace is good? Is there power in the relay socket probably contact number 30, just guessing.
Losing my mind
yes ran power to fan it works but I am not getting power to the fan wires from relay the relay works checked it still clicks replaced grounds still nothing replaced all fuses to it was working was driving pretty fast and threw out the relay if one relay goes out will it crap out a couple more but I wonder if because I have a three prong hook up on the fan I have the old one had two could the remote wire for the new fan cause the relay to short out because of the signal wire the new fan has that the old don't
Figured it out
I checked fan it worked checked Windows they worked checked wipers they worked so I checked relay after relay got to the big prong 206 relief relay and the ol bugger tired out on me threw in a muti purpose fuse to see if it was the problem for sure and try my Windows and every thing else works to it was a pain in the butt aaaaaaaa. 5Zylinder love baby
Luxus Panzer
06-02-2004 07:11 PM
joemg
02-14-2004 05:12 PM
washburn33
Performance and Tuning
10-02-2003 11:26 AM
