Looking for an air filter cold air intake hose for my 87 4kq
Old 02-24-2009, 11:04 AM
New Member
dtnaughton's Avatar
Default Looking for an air filter cold air intake hose for my 87 4kq
None of the local import distrubuters or the audi dealers seem to be able to locate one. Any help including a point in the right direction would be greatly appreciated.
Old 02-24-2009, 11:45 AM
vair_17's Avatar
Default Re: Looking for an air filter cold air intake hose for my 87 4kq
IIRC you cant put a cold air intake on a cis-e car(flame war) but if you where going to try to get one its way easier to make one then to buy one.
trust me i work at a parts store i have teenagers come in almost every day to get one ordered. if you where looking for a cone filter the local parts store should have a bunch bit he pipe you should make.
good luck.
vair_17
Old 02-24-2009, 12:09 PM
New Member
dtnaughton's Avatar
This isn't any kind of modification. I am just trying to replace the original cold air intake hose. The hose is an odd size for which I am not having much luck finding a replacement. The inside diameter is just over 2-3/4" or about 70 mm.
Old 02-24-2009, 12:22 PM
AudiSport4000's Avatar
Default Explain
Is this an OEM part of the stock airbox?
Old 02-24-2009, 12:33 PM
Default I see...
Is it the hose that goes from the airbox to exhaust manifold?
Old 02-24-2009, 12:55 PM
New Member
dtnaughton's Avatar
Nope - I have that one - This is the larger diameter cold air hose
Old 02-24-2009, 02:19 PM
CGTBrad's Avatar
Default I replaced mine with a piece of Aeroduct SCAT.
Though, it's not recommended for negative pressure applications, I've not had a problem.
OTOH, I ran without any tube there for a long time, with no problems either.<ul><li><a href="http://www.aircraftspruce.com/catalog/appages/scat.php">http://www.aircraftspruce.com/catalog/appages/scat.php</a</li></ul>
Old 02-24-2009, 02:42 PM
New Member
dtnaughton's Avatar
Were you able to make the 2-3/4" fit or did you have to use 3"?
Old 02-24-2009, 03:22 PM
WRC_4kqt's Avatar
Default Are you talking about this?
<center><img src="http://pictureposter.audiworld.com/153495/019000.jpg"></center><p>
Number 22?
It should still be available from a dealer. I most people will not have one in very good shape unless someone has replace theirs recently. It's basically made from wire and paper.
Old 02-24-2009, 04:24 PM
CGTBrad's Avatar
That'd be it.
Quick Reply: Looking for an air filter cold air intake hose for my 87 4kq
