Low amps from coil
Low amps from coil
This is regarding an 4000 CS Quattro.
Have only about half the amps I should at the coil. Car starts but will only run for a few seconds. Have replaced the coil to no avail. Any ideas?
Thanks!
Tom
Thanks!
Tom
Have you checked the Hall sender? If it's bad, generally the fuel pump will not run also, which makes it easy to tell. But those can start to fail and cause some odd problems and then when they finally go the car becomes a giant paperweight.
Other than checking all the wiring, there's not a whole lot else in that chain. Is anything else not working right?
-Rog
-Rog
I'd start by checking the fuel pump relay. Try going into the fuse box and pulling the relay (I think its in position 13?) and fashion a jumper between the two large spades. This will have the fuel pump come on (so don't leave the jumper in after the test) then try to start the car. If the car runs normal - you simply need to replace the relay.
Beats trying to track one down. None of my local parts stores carry them.
-Rog
DoraBug
05-10-2005 04:17 PM
LarryF_in_Ca
04-12-2005 08:24 AM
