Replaced oil sending unit/ still a large puddle
Old 06-13-2004, 01:51 PM
Alpine 87.5's Avatar
Default Replaced oil sending unit/ still a large puddle
So I replaced the oil sending unit yesterday, along with new 5w30 GTX/ & filter. It only leaks after i drive it. So when i got home from the garage I took a look and sure enough oil is dripping again. I cannot place this damn thing cause theres oil all over the bottom of the engine. If I pressure wash it off it won't leak till after i drive it resulting in more oil everywhere. I am buying a new oil pan seal tomarrow. Anything else on the bottom front of the engine that I can replace to maybe stop this leak? Im pretty sure it's the pan seal now/ but I thought I was sure it was the sending unit.
Old 06-13-2004, 01:53 PM
AudiSport4000's Avatar
Default Re: Replaced oil sending unit/ still a large puddle
Have you done your valve cover gasket? I leaked oil all down the side of the block, and eventually it would leak on that sensor, and onto the ground. Replacing the VC gasket worked for me. I have an extra oil pan gasket incase mine ever goes sour.
Mike
Old 06-13-2004, 02:00 PM
yep/ Twice
Old 06-13-2004, 02:40 PM
Then Id say oil pan gasket
Old 06-13-2004, 02:53 PM
gmbchef's Avatar
Has the timing belt been changed recently?
Old 06-13-2004, 03:02 PM
DBF
Junior Member
DBF's Avatar
Default 5w30?
I wouldn't put anything less than 15w40, and preferably 20w50 during the warm months, in any vintage vag car. I doubt if that is the root of the problem but I suspect a thinner oil wouldn't help your cause that much. Try a heavier oil. And a proper mann, bosch or mahle filter. You just never know.
Old 06-13-2004, 05:08 PM
4corners's Avatar
There are two sendors. Did you replace both?
Old 06-13-2004, 08:28 PM
Default Re: Has the timing belt been changed recently?
changed probally 6k mi ago. I did use a bosch filter, Dad already had the oil. It's gotta get changed again anyways. Where is the other oil sending unit at? I changed the one on the very front bottom of the engine/ right in front of the oil pan.
Old 06-14-2004, 01:03 AM
New Member
Audimagic's Avatar
Default my experience
Mine has similar leaks (4ks), I found it to be leaking from the head gasket at the upper right rear corner of the motor, easily obscured from view unless looking through the wheel well with a light. It only leaks when you stop running as the oil returns through the oil galleys to the pan, I'm going to re-torque the head bolts another 5-10# to see if that helps.
Old 06-14-2004, 02:37 AM
Junior Member
EuroTrasher's Avatar
Default VC gasket
Guy I bought my coupe from said he couldn't get the valve cover to quit leaking until he but on one from a 5k turbo.
Quick Reply: Replaced oil sending unit/ still a large puddle
