so then a new problem...
ok so i replaced the blown coolant hose yesterday and was putting it back together today. i got it back together and put some coolant in. i go to start it up i turn the key the dash comes on the fuel pump primes and all seems well. i go to crank it.... everything shuts off like the battery is dead. battery is not dead, what could be the problem??
One of the battery terminals not quite tight enough?
Things will work ok, until you need lots of current.
Then, a little 'snap', and the connection goes open. If so, just snug them down again, and may be ok..
loose wire/connection. check both positive and negative cables, start to finish. it may be a broken
cable so try to feel for any breaks or soft spots. if you can't find any loose connections and everything seems fine, i would replace both battery cables. that's probably where the problem is if everything is tight.
SnowZach
11-14-2003 06:39 AM
Muhammad
Audi 100 / A6 (C4 Platform)
08-18-2002 09:01 PM
