throttle cable/ gas pedal connector
the thing that connects the throttle to the gas pedal keeps comming disconected causing me to crawl under there and fix it at inoppertune times (busy streets , merging) it seems to be that the grommet (rubber thing whatever that held it in lace has worn out any ideas?
i thoug glue but it's too tight for my mannish hands to fit a glue bottle up there anything |
Force5 has replacement bushings for about $5. HUGE pita to install.
if I can respond to my own post......
<ul><li><a href="https://forums.audiworld.com/4000/msgs/12846.phtml">description of what you're about to go through</a></li></ul>
It's ghetto, but mine is held together with zip ties.
That's about the opposite of my experience.
The hardest part for me was finding the U clip when I took off the gas pedal and it slid under the floor mat.
You've gotta take the throttle pedal off. 2 u clips. FWIR, I think you only have to take 1 off though. Then pop out the old bushings and pop in the new bushings. 45 seconds like you said ;) If you have a 4kq, you need 2x of 431 721 559. If it's a CGT you need only 1. |
Theres my problem
i only have one bushing and no u clips
i zipptied mine with much cursing and heavy breathing it's almost as if this car werent builtfor a 6' 4" mechanic hmmmmmm..... thanks anyway rock and roll |
Why is that a problem?
Just buy a new bushing and clips. Probably cost you $7.
The hard part for me was putting the throttle cable into the bushing.
There's zero space to put your hands/arms. Oh well, it's water under the bridge at this point.
JD |
Not to bad of a job really...
I found it to be a pain in the ass if you leave the lower part of the dash in place while trying to install the bushing.
Turns into a really easy job if you take the lower dash out first (which is also an easy job). Have done it twice now, once on a 2Bennett loaner car 4KQ (with dash in place - PITA). Once on my 4KCSQ (took out dash - 2 minute job). |
I remember that now...
I think I snapped it together with a pair of channel locks IIRC. You're right, no room for the hands.
