Where the hell is the oil temp sensor?
I pulled the pan today and I did not find a sensor. There was a wire that runs along the bottom of the oil pan that goes to a sensor that is in between the front of the pan and behind the crank pulley. Does the oil pressure sensor take the temp too? I cant find where the sensor in the bentley manual either. Anyone have any ideas?
You found the temp sensor. The pressure switches are on the drivers side of the block
So that wire that runs down the pan is the oil temp sensor?
yep
So will it drain out oil if I remove it?
