1990 MC2-engine is giving me the irrits (running lean)
Old 11-07-2011, 01:08 PM
little_e's Avatar
Default 1990 MC2-engine is giving me the irrits (running lean)
This engine has troubled me for months now. It started early this summer with a misfire now and then, and around the middle of July the car started to misfire so badly it's virtually undriveable.
All spark plugs are white as snow, and I can only press the accelerator in like 20-25% before the car starts to misfire.
I've replaced every (all new parts) sensor, all hoses, the coil, ignition leads, new spark plugs, fuel injector, Bosch 040 fuel pump, done a pressure test, tested fuel output from the pump and checked pressures in the CIS, everything within spec, taken out the tuning chip and put the original chip back in, checked the fuel distributor for a sticking plunger, checked for fault codes...
...and all this to no avail.
Any thoughts as to what my problem could be?
audiawd310
08-22-2018 12:18 PM
Lbcavant
A4 (B7 Platform) Discussion
17
05-26-2017 01:26 PM
extrabolts
11
08-31-2008 03:04 PM
dgkula
02-24-2007 05:33 AM
mow
09-18-2002 04:42 PM
Quick Reply: 1990 MC2-engine is giving me the irrits (running lean)
