1991 200 Quattro Ignition switch replacement problem
my ignition switch broke. And it burnt out the wire going to my starter.I replaced the starter and the switch
Import Direct Ignition - Ignition Switch Part # 18-0550 Once I plugged it in, I turned the ignition switch with a flathead screwdriver before inserting it into the back of the lock cylinder. The car started. But, no matter how many times I insert it into the locking cylinder, I cant get the key to turn on the car. I saw a mechanism in the back of the cylinder that obviously syncs up with the switch and locks into some grooves.However, no matter how many times I try and slide it in place, it never works. Heres a few pics of the switch and the back of the locking cylinder. Its extremely hard to take pics of the locking cylinder, since its so deep in the dash. https://drive.google.com/file/d/0B0b...ew?usp=sharing https://drive.google.com/file/d/0B0b...ew?usp=sharing https://drive.google.com/file/d/0B0b...ew?usp=sharing Does anyone know how to install the switch properly, so I can turn my car on again? |
3 Attachment(s)
I attached the pics I linked to above.I couldnt find out how to edit my post
Looks like the tang at the end of the lock cylinder is broken time for new a lock cylinder.
@yodasfro
Yes youre right,I think the lock cylinder is broken.Do you know where I can find a guide to replace it?All the guides Ive found are years old and the picture links are dead. |
Easiest thing to do would be to replace the whole housing with a good used one.
It's held to the column with one anti-tamper torx bolt. If you need one I have a few good used ones. |
I appreciate the offer
Originally Posted by yodasfro
(Post 24675092)
It's held to the column with one anti-tamper torx bolt. If you need one I have a few good used ones. [V8] Ignition Lock Assy R&R? |
If by easier you mean the same exact thing then sure.
Replacing the lock assembly tumbler is easier than replacing the lock housing.They are two different parts
