central locks on a 200
Old 05-29-2003, 11:37 AM
Randolph's Avatar
Default central locks on a 200
Is the central locking system on a 200 the same system as on a 5000 with the vacuum pump and the vacuum actuators in all the doors. For those that have read my other posts on my central lock problem I've determined (I hope) that my driver actuator is bad. The local yard has a 1990 200 that I'd like to take the actuator off of if it's the same part. I'm not sure what the dealer charges for this part.
Randolph
87 5KCSTQ
93 928GTS
Old 05-29-2003, 12:48 PM
Member
Will Ng's Avatar
Default 200's use vacuum actuation.
You should grab both front doors, and the trunk lock while you're at it.
Old 05-30-2003, 05:04 PM
Junior Member
DaveN's Avatar
Default I would bet on a cracked line first...
the one in the rubber boot going to your door. Check the wiring while you're looking.
Old 05-30-2003, 05:28 PM
cuatrokoop's Avatar
Default Re: central locks on a 200
if you need any central lock stuff, I can pull it from the '86 TQ...All the door panels are off, so its easy to get too. Gotta love parts cars...
briangates
28
05-25-2020 04:36 PM
Jrowell111
01-02-2015 02:51 AM
lakerns
Audi Original "S" Cars
12-05-2005 09:16 AM
Kapoosh1
9
04-18-2005 04:16 PM
frank34
02-18-2004 03:55 AM
Quick Reply: central locks on a 200
