Fluid on the floor - '87 5kqt - HELP!
Old 05-19-2017, 07:18 AM
pariseaudi's Avatar
Default Fluid on the floor - '87 5kqt - HELP!
My '87 5000CS quattro leaks hydraulic fluid on the driver side floorboard from somewhere. I can't figure out where it's coming from! I don't see any noticeable fluid level drop from any of the reservoirs. Clutch and brakes both work fine, though the brake "bomb" might be on its way out given the vibration in the brake pedal and delay in power assist when I stand on the brakes. Any ideas?
Old 05-19-2017, 10:01 AM
a-talk's Avatar
I would suspect the hydraulic brake booster, which uses boost from the PS pump to provide power assist to the brakes. If you shine a flashlight underneath the dash (with the kick panel off) you can see it at the end of the brake pedal assembly.
Old 05-23-2017, 08:14 AM
pariseaudi's Avatar
Thanks, a-talk. I will check that. The fluid looks amber, not blue like the hydraulic fluid from the pump, but it could be just because the carpet is dirty.
The Red October
12
01-10-2008 08:31 AM
Paul91
06-18-2006 07:49 PM
TwisTTer
15
08-10-2005 10:45 AM
00zero
Audi Original "S" Cars
08-09-2004 07:34 PM
00zero
07-12-2004 01:20 PM
Quick Reply: Fluid on the floor - '87 5kqt - HELP!
