Fresh Air/Recirculation Flap Return Spring
Old 03-04-2003, 05:08 AM
Hatterasman's Avatar
Default Fresh Air/Recirculation Flap Return Spring
I searched for and found information regarding window fogging problems that pointed me to the return spring for the recirc flap. Sure enough, it's broken. I found it dangling from the back of the flap. My question is where did it hook up? Does it hook to the bottom of the vacuum servo bracket? The Bentley manual does not seem to even show the spring. I can only find instructions for replacing the vacuum servo.
Old 03-04-2003, 06:29 AM
New Member
86_5K's Avatar
Default No, Bentley is not clear on that one...
There should be a bar between the vacuum servo hookup and the recirc flap. In your situation, the bar must have snapped in the middle. So, don't try to hook up the spring before you fix that. Once I fixed that using two hose clamp clamps a metal stick(a bolt for example) onto the broken plastic bar.
Zhaoming
Old 03-04-2003, 06:38 AM
Default I unraveled the end of the spring, bent a new hook
Thanks for the info. I thought it looked like it went up there, but I wasn't sure. I unraveled the end of the spring, bent a new hook on the end of it and reconnected it to the plastic "bar" under the servo and it works. An easy and cheap fix for an Audi! That's a first.
Jeff
91 V8Q
Old 03-04-2003, 06:48 AM
New Member
86_5K's Avatar
Good to hear.
Old 03-04-2003, 07:07 PM
audinatic's Avatar
Default Re: Fresh Air/Recirculation Flap Return Spring
Hi, do you access this spring from the engine compartment or under the dash on the passenger side?
Thanks.
Old 03-04-2003, 09:16 PM
tonyj's Avatar
Under the dash. Fairly easy once you get the glove box, tray and heater duct out of the way.
Tony
'91 100Q 5spd
Old 03-05-2003, 07:50 AM
audinatic's Avatar
Tony, thanks for the info.
Tony.
Sloooo4esT
Audi Original "S" Cars
05-14-2006 09:01 PM
boxerfan
01-05-2006 12:06 PM
2quattroaudis
12-20-2004 09:29 AM
charles 200TQ
03-15-2004 03:18 PM
tim200tq
16
10-20-2003 06:20 AM
Quick Reply: Fresh Air/Recirculation Flap Return Spring
