Heater Core hoses
Old 11-22-2012, 07:36 PM
auto-union-nsu's Avatar
Default Heater Core hoses
Hello
In my haste I'm not sure of the Heater Core hose placement
I also replaced the heater core hoses along with the heater core
I did a search but I just want to make sure ..
Does the bottom outlet on the heater core go to the hose to the block
and the top outlet from the heater core go to the pipe to the water pump ...
Thanks In advance
Any pics much appreciated
Old 11-24-2012, 01:51 PM
audi_marv's Avatar
Default Heater box diagram
http://www.jimellisaudiparts.com/showAssembly.aspx?ukey_assembly=753092&ukey_make=1 081&ukey_model=15611&modelYear=1986&ukey_category= 21735&ukey_driveLine=8049&searchString=heater+core[/IMG]
this is for a 5000 turbo. bottom of photo shows heater core and hose connections. it appears the top outlet connects to the hose that has the heater valve on it....which would be the hose to the block.
Old 11-24-2012, 03:13 PM
Kneale Brownson's Avatar
Same arrangement for the 20-valve engines.
Old 11-26-2012, 08:45 AM
Default heater hoses
Thanks for the replies
Well I figured out my problem
The image on the Left is from a 200 Q
The image on the right is from a 5000 1984 .. the car I replaced the heater core in is a 5000 84
Notice the image on the Left the coolant pipe [#4] coming from the water pump
connects to the top connection of the heater core ..
The image on the right for the 1984 5000 [#4] in the image connects to the bottom connection of the heater core ....
The image for the 84 5000 is wrong... [both images are originally from ETKA] part numbers for the heater core are the same for the 84 5000 and the 200 Q ....443-819-030...
The heater cores are the same so IMO the connections should be the same..
I was experiencing higher coolant temps. in stop and go traffic with the hoses reversed ...gauge was going to the second line past from the middle of the gauge in traffic ....now with the heater hoses in the correct positions ...
The temp gauge barely reads past the middle line of the gauge in traffic ..
Hope this post helps someone in the future ....
choptt
Audi allroad
11-08-2011 05:42 PM
catch2otwo
12-14-2010 06:16 AM
catch2otwo
12-14-2010 04:53 AM
jitsu303
05-09-2006 04:40 AM
DudeDah
01-13-2005 05:37 PM
Quick Reply: Heater Core hoses
