Go Back  AudiWorld Forums > Audi Models > Other Audi > Audi 5000 / 200 / V8 Discussion
Reload this Page >
Project thread reviving a 1991 Avant
Old 03-08-2019, 07:56 AM
  #11
Hendie's Avatar
Default When my brakes are done
Next project after brakes are done.
Hendie is offline
Old 03-12-2019, 01:17 PM
  #12
Hendie's Avatar
Default Rant
E-brake cables on these cars are a **** to change with out a lift! Trying to get what's left of the clip near the adjuster out! Nothing left to grab.
Hendie is offline
Old 03-14-2019, 11:14 AM
  #13
Hendie's Avatar
Default Need parts!
Got the e-brake cable out. But I had to cut it. And the end that I cut is not coming free of the adjuster. The adjuster also appears to be damaged. Looks like I have to cut the adjuster out and replace it. If anyone has one with the t shaped piece on the end please pm me!
Hendie is offline
Old 03-16-2019, 10:57 AM
  #14
Hendie's Avatar
Default It's all apart finally!
Now to reassemble tonight after work. Can't wait to start driving it again!
Thinking about modifying a Autometer 20020 to work in my 200. Anyone try this? I need to install a few more gauges than originally planned.
Hendie is offline
Old 03-22-2019, 09:40 AM
  #15
Hendie's Avatar
Default Passengers Side done
Just waiting for warmer weather to do the other side.
Hendie is offline
Old 03-26-2019, 06:29 AM
  #16
Hendie's Avatar
Default Magnetic oil plug arrived
And painted my waste gate cap.
Attached Thumbnails Project thread reviving a 1991 Avant-img_20190324_154758.jpg
Hendie is offline
Old 03-27-2019, 03:35 AM
  #17
Hendie's Avatar
Default Painted cap installed
Hendie is offline
Old 04-20-2019, 07:34 PM
  #18
Hendie's Avatar
Default Driver side rear
Brake rebuilt. New treads on the rear. E-brake works perfect. Now my stinking fronts are dragging. At low speeds and when turning?WTF? Big reds I believe. They are from 2bennet not sure what they were designed for originally. I'm leaning towards a bad master cylinder and stuck proportioning valve though. Since blowing a brake line started all this. And I had a few miles to go to get home. I'm betting the master went dry. I did the bomb test hard first pump! Fail. Would like to rebuild calipers for peace of mind. Just need to figure out what to get a seal kit for. And wait for my pressure bleeder to show up.(did it old-school and think I've still got air) In the meantime take the bomb off my parts car and try it. The noise from the the brakes when turning has me concerned enough to park the car. Again. This car is almost as stubborn as me. She saw my buddies 4k which has original paint parked in her stall and threw a tantrum!
Attached Thumbnails Project thread reviving a 1991 Avant-img_20190420_130231.jpg
Hendie is offline
Old 06-25-2019, 05:01 AM
  #19
Hendie's Avatar
Default More goodies! Need vag 2069!
Figured time for a new front suspension. Since my control arm broke. But I need the strut insert tool. Anyone have one they can part with?
Hendie is offline
Old 07-12-2019, 09:05 AM
  #20
Hendie's Avatar
Default Aquired vag 2026
However The S4 sub plates supplyed by 2Bennett for my camber kit. Do not fit my upper spring pearchs. So Im stuck waiting for parts again. Shes all torn appart beggin to be put together.
Attached Thumbnails Project thread reviving a 1991 Avant-img_20190711_214919.jpg
Hendie is offline
kk's woW12
07-28-2011 11:18 PM
Scot J
01-04-2008 10:19 AM
PhilJ
03-14-1999 04:14 AM
stevebrown
10-27-1998 11:13 AM
Quick Reply: Project thread reviving a 1991 Avant
