Window Regulator - 1986 5000 CS Turbo
Search 443837397d - 443837397D - Window Regulator - Left Front, Includes Motor. - ES#5506
Repairing the cable is likely more trouble than it's worth.
A good used one is another option. What usually happens is the rubber isolator bushings break from the torque of the motor then the cable goes crunch.
So if going used might want to get new bushings.
You can also look here.....
Did this last year, same side. Remember to fine sand and lube the metal window guide as it will be pitted and rusted.
$45 Audi Left Front Window Lifter Motor 100/0 5000 V8 443837397D
Hendie
03-01-2019 09:55 AM
heinzboy57
12-03-2008 06:32 PM
skidmark
Audi allroad
17
06-20-2005 05:48 AM
