1988 Quattro NG - starter system replacement
I Was wondering if anyone knew how the starter is wired up in a 1988 Quattro 2.3 NG. I bought the car with a jerry rigged push starter (you have to put the keys in the ignition, turn the keys to on and then push a push button to engage the starter). I was planning on fixing this.i was wondering if anyone knew >what sort of relay and how powerful of a fuse i should use and appropriate gauge wire< (to hook up from the ignition, i have a new switch) i was going to use this diagram pretty much. I have a replacement ignition switch i believe the previous one is broken.
1988 Audi 90 Quattro 2.3 NG 5 speed
What id like to know
What size and type of relay i should use
gauge wire
fuse size
terminal connection on the starter
Thank you,
gauge wire
fuse size
Thank you,
Yoshimura
07-14-2019 06:48 PM
XcellR8edAudi
Quattro: Turbo / Ur / Sport
08-02-2004 06:18 PM
S4NoRice
07-09-2003 07:53 PM
