1996 cabriolet, no low beams or fogs
no power at low beam lamps or fog light lamps. please help with where to start and work me through the progression for troubleshooting. fuses and relays look good... love the car, runs and drives great for a car with no maintenance history
also, when driving car home i hit cruise control and it made the tach go to zero and now revs bounce around randomly instead of telling you what rpms are accurately...not sue if related in any way
ok, despite lack of interest an update. took off steering wheel to remove headlight stalk/switch, no melting of any plastic. polished up contacts anyway and reassembled... still no low beams. pls help me on what to check next
http://12v.org/urs/1996_Audi_Cabriol...g_Diagrams.pdf
Look at page 24 for the headlamp wiring. Looks like two fuses for the low beams..odds are both fuses being bad are very low..but check them anyways.
The fog lamps and headlamps do have a common ground..but the high beams should be a problem too. I would check the headlamp grounds G202..which should be on the left side front chassis..maybe. Look around and do be sure any brown wires that ground anywhere are in great condition.
LOw beams are the yellow or yellow and black wires..see if you have 12v at those wires at the headlamp..if not..start backing up to the switch
W261w261
04-11-2015 08:44 PM
gt4mx5
08-26-2007 03:24 PM
A6 4.2/S4 Portlnd OR
03-17-2007 07:05 AM
audijim113
Audi 100 / A6 (C4 Platform)
01-04-2006 11:26 PM
