88 NG 90q driveablilty/timing 2 issues
First off, hi there. 88 90Q with an NG up here in Maine. I was a member a LOOONG time ago, with an email address I havent been in in 2 years (and different 80's audis, coupe GT, 5K avant q, another 90q etc.). So I had to re-register.
My 88's issue is this. Around a month ago I hit a puddle and the engine bogged down something fierce. Pulled the Timing 2 fuse and it came back to life, albeit with reduced power. Dried out for the weekend, put timing 2 fuse back in. Drive for a few days, no issue. CEL comes on on the highway, get off my usual exit, bogs down (not wet out). Pull timing 2, gets me home. Checked CEL, flashes code 1-1-1-1. try to start with T2 fuse pulled, no go. Now it seems like every time I start it, once it warms up I have to pull the timing 2 fuse and limp around. Coolant temp sensor for ecu replaced (the one underneath) last week, no vac leaks, hall sensor connector was soft, I repaired that. New plugs, wires, cap, rotor done recently just as routine maintenance. Synthetic since new, was well cared for. This is just frustrating. Thanks in advance for the tips |
whats 1-1-1-1? i dont know the codes for the I5 engine :(
Flash Code 1111
Fault Source Control unit Symptom Engine does not start Possible Cause - Fault in control unit ground wiring - Microprocessor in MPI control unit is faulty Fault Correction - Check ground connections - Replace MPI control unit |
Code 1-1-1-1 (nothing wrong) on this engine is normal and varia mentioned already, check the wiring from ECU to every sensor , connection and ground circuit includes engine to negative of Battery.
Thanks all, it ended up being a bad wire to the ect and a bad ground to the block!
Running great now, no codes |
Originally Posted by Maine90q
(Post 24546012)
Nice:)
where in Maine are you? |
