AFC tensioner on the AAH
Has anybody ever tried to put a AB tensioner on a AAH which the updated [now obsolete] Q is supposed to go?
They look exactly the same, only difference is a male 17mm hex to release tension vs a 10mm female hex port.
The correct belt is also 1860-1862 mm instead of 1905, not sure why since the route is the exact same for both engines with roller
delete and AC.
AB you can get OEM Litens for a good price vs Q which are Meyle or URO and they cost much more.
delete and AC.
Hmm so nobody with the AAH has attempted to use the AB tensioner which is technically for the AFC [updated] but from what I can tell they are the same exact tensioner as the Q version, just 1/4 the price since Q seems to have been superceded.
Yes you can still get the Q from the dealer if you want to pay 4x the price.
1905mm belt length was the so called correct length but you can also go with 1860-1863 depending on if you use Conti elite or the original belt, the tensioner has enough slack to compensate for another 1 3/4 inch length.
04 allroad
Audi allroad
02-03-2009 01:00 PM
SDSilver01
08-10-2004 10:26 AM
Xymox007
01-08-2003 08:35 AM
