Audi Cabriolet bucking on gear change
Old 04-18-2019, 08:35 AM
Andy savvides's Avatar
Default Audi Cabriolet bucking on gear change
Hi,
Does anyone have a view on this issue? My Audi Cab (1998 1.8) is hard to start. When it starts, it splutters in to life and then settles down. When driving, there is a noticeable loss of power and then over compensation in acceleration making the ride jurkey (especially when you change between first and second gear). When reversing, the revs can drop off and the car stalls. Its been in the garage, so far they have replaced the fuel injectors (for a refurbished set) and the Mass Air Flow Meter. Annoyingly, before I started down this route starting it was fine, the car ran smoother, however, petrol intake was rich, fuel burned quickly and there was a slight misfire ever so often.
Any pointers much appreciated
Thanks,
Andy
Old 04-19-2019, 08:30 AM
mambe_pambe_quattro's Avatar
Hello,
Replaced fuel injectors and maf sensor? How about the spark plugs? This would be next on the list for me.
Running rich..might want to check the fuel pressure as there may be insufficient fuel delivery.
Also vacuum lines can stall things as well, so make sure these are not cracked,crusty, and seated property.
Thanks,
-mambe_pambe
Old 04-20-2019, 01:51 AM
Thanks Mambe,
I am also wondering if it could be the refurbished fuel injectors, as things got worse once these were in. The garage thought it could just be that it exposes another issue. Thing is, now the MAF has been replaced and they have fiddled with the timing, its even worse i.e now have the bucking acceleration on gear change and emissions are very smelly
Wish I just stuck with the initial issue which was a very small misfire when idle. everything else was working fine at that point
LaserSVT
02-19-2018 08:06 AM
videoviking
06-14-2005 03:57 PM
audi90_quattro
09-20-2004 09:00 PM
Aussieguy
01-31-2003 09:43 PM
DRennick
05-11-2002 07:11 AM
Quick Reply: Audi Cabriolet bucking on gear change
