big problems here after 3" intake/XTB install
Got it all in there, however, when I start my car..the revs start high and keep climbing until I am forced to shut the car off or be doing 7K RPM's in neutral.
Anyone know what is going on??
sounds like your throttle cable or TB pulley is stuck or binding on something. I've had it happen...
once and very early-on. If the butterflies aren't open/stuck open the car can't make RPMs.
Re: sounds like a throttle cable problem
yes they seem to be..even if I hold butterfly closed with hand at my throttle body...it still happens??
I am at a freakin loss...
Maybe unplug battery and reset computer????
Re: sounds like your throttle cable or TB pulley is stuck or binding on something. I've had it happe
the rpm's seem to climb at a stedy/fast rate...does that help?
ok ..I put some mussle into closing the butterflys and...
they snapped shut...they seem to be catchung on something on the inside of the throttle body...??
Feels like metal on metal....ganna start her up with them closed and see what happens...
I'm betting its an external obstruction. Hold a mirror down there with...
a light and look inside. But only after checking the outside near butterfly pully and cruise control area on top side of TB when mounted.
