Cab question #2. Axle seal leaking
Ok, while inspecting the underside of the Cab while letting my tranny drain, I found oil all over under the car. It is coming from the driver's side axle shaft seal. Just a minor setback, since I already knew the axles would have to be replaced. Both outer boots are torn up.
The car has a CFS transmisson. The correct seal appears to be oe# 097409400D. Here's the question(s). How will I replace the lost gear oil? Can the level be checked? Is there a differential fill hole? What is the proper viscosity? The manual says it is sealed for life. |
can you please place your vehicle year and model in your signature.
also, i think the cab that we converted from an auto to a manual has good axles and other parts that came out of it if you are interested. |
I updated my signature. I hope I did it correctly. I would most certainly be interested in a pair of axles. What would it cost me to have a pair shipped to Wisconsin. Zip 54956. I'm going to check the onex on the Cab at the local junkyard. Maybe they would be useable also.
unfortunately they are EMPI, not oem, if you are interested, make an offer, shipping will be about $30
