check engine light
check engine light
after starting from cold for about 5-10 minutes the check engine light comes on. when i turn off the ignition and then restart it will be off, and i can drive it indefinately and the check engine light won't come on. after i restart it i noticed it idles a bit lower. is there any way to pull the engine codes (other than something like VAG-COM) to see what it is?
thanks in advance
thanks in advance
You can do it with a fuse in your car......
It has different cars listed but this method....<a href="http://www.sjmautotechnik.com/ecuf.html"><b>works on your car!</b></a>
Good Luck!!
Good Luck!!
PDX95A6QWagon
Audi 100 / A6 (C4 Platform)
12-30-2006 12:24 PM
rabbid
12-03-2003 07:03 AM
