Custom Intake Project: cold air intake, 3" MAF conversion, 034 silicone hose, & cleaned TB
Resolved a couple idle issues as well.
New Parts:
-<a href="http://www.034motorsport.com/product_info.php?products_id=18022">034 Motorsports Silicone Hose</a>
-3" MAF, 078 133 471A
-AEM DryFlow 5" Short Neck Conical Filter
-Custom 3" Hosing/Piping
-4" Hose Clamps
-Adjusted Idle Switch
-Throttle Potentiometer replaced
New MAF:
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02401_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02402_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02403_small.jpg">
New 034 Silicone piece
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02404_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02405_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02406_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02407_small.jpg">
Attached to the MAF
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02408_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02409_small.jpg">
Inside of the MAF
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02410_small.jpg">
Burnt TP sensor, pretty sure a piece broke off on the inside. Something was moving around in there. I carefully installed the new one, not to break anything.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02418_small.jpg">
New TP sensor
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02466_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02467_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02468_small.jpg">
Protective measures
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02469_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02470_small.jpg">
New 4" Hose Clamps
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02464_small.jpg">
Audi Style
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02465_small.jpg">
Adjusted Idle switch to actually touch the TB tab.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02448_small.jpg">
Got dirt?
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02445_small.jpg">
Closer look inside..
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02447_small.jpg">
<FLAME SUIT ON>
I had to do something drastic to get the cone filter away from the hot engine, there was a piece of thin sheet metal in between a lower opening. I took advantage of this. Car actually sounds amazing in between this and the exhaust. Runs much more spirited and does not lag after it starts to warm up (breathing in hot air).
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02397_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02398_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/DSC02242_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/DSC02231_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02399_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/DSC02235_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/DSC02240_small.jpg">
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/DSC02251_small.jpg">
I sanded off the groves on the plug of the 3" MAF. It is a plugNplay swap. I will see how it runs, so far so good. I believe the fourth pin needs to be tweaked so the resistance is proper, but as of right now it runs nice and smooth.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02455_small.jpg">
Final product, forgot to take a quick picture after the new hose clamps were on. Those zip ties were only temporary.
<img src="http://i141.photobucket.com/albums/r42/mycarprojects/MY1990Audi90/air_intake/install/DSC02453_small.jpg">
New Parts:
-4" Hose Clamps
New MAF:
Attached to the MAF
Inside of the MAF
New TP sensor
Protective measures
New 4" Hose Clamps
Audi Style
Got dirt?
<FLAME SUIT ON>
Looking for something else, that is a little bit more on the flexible side.
Drove it about 40 miles like it is now. Runs great. Drove the air intake hosing and filter for over 300 miles, runs fantastic. I would like to replace it with silicone, we will see.
Looks like your having fun, but the ribbed tubing....
Car manufacturers used to use ribbed tubing on the inside of the seemingly smooth intake tubes to slow down air flow (they also used neck downs and other ways of slowing and defining the intake)..
Didn't 034 determine that large bore MAF swap on 7As had no effect??
They tried to do it but their dyno showed no increase in power, thus no new software for that.
Also, I would route your filter elsewhere...any stronger rain you get caught in may result in this:
<img src="http://www.matts-workshop.com/mdsale/Images/bent_rod.jpg">
