engine tick
5 cylinder 10v, when revving up engine there is a intermittent loud ticking noise coming up and disappears on and off, what is the most common problem, the valve lifters or the rod to work the vacuum pump?
Thanks for the input, Willem |
Vacuum pump rod and you can remove it without it effecting the brakes usually.
Oil level is Ok and when did you change oil?
How you can see the oil pressure on gauge? 3 ~ 4 bar when Rev up and idling about over 1 bar when engine warm. I'm driving the 10 valves engine(248.000 miles on) without changing OIL 6 year( just top off when need) since I use the OIL cleaning device and driving to 27.000 miles now. x19 |
Will try, however it is obsolete at the dealer, any ideas where it would be available?
Thank you, Willem |
yes, just changed the oil
Originally Posted by x19
(Post 24578444)
