How long can I run the Cabie on low test?
would this work???
or does the cost canel out the savings<ul><li><a href="http://www.fppf.com/prdOctaneB01.html">hmmmmm.</a></li></ul>
When I start pinging I'll try it
She's not going to like you very much if you do, I would alternate fill-ups
Low then high if you can.
That's what knock sensors are for.....
Sister runs 87 in her '98 all the time, and I only ever run 87 in the 5kq. The knock sensing equipment does work, you'll loose a little performance, but in normal driving you won't notice.
Forever, as long as you use this...................
I have run 9,000 miles on 87 with the Fitch.
No knocks. Runs fine.<ul><li><a href="http://www.fitchfuelcatalyst.com/">http://www.fitchfuelcatalyst.com/</a</li></ul> |
