IOS: 12v engine
Looking for low mileage 12v for my 93 audi 90
Originally Posted by goodys90
(Post 24632086)
What engine should I go with I'm aware that if I go with afc engine that I have to have the downpipes as well. But which is the over all better engine? Aah or afc? Afc with aah cams is the way to go. I also found a set 283 cams from catcams. I also have m200 ecu. Gasket matched intake, tb gasket matched to intake, 4 to 3 wire maf conversion, with new motor will bring gasket matching intake to heads and ecm tuning by 034.
(Post 24632849)
where did you find the cams?
Originally Posted by CRAZY_RUSSIAN
(Post 24632932)
(Post 24632935)
http://www.catcams.co.uk/
they work on the 2.8.
i thought you found some here in US |
I'll be pulling an AAH out of my '94 Cabriolet sometime before spring. 75k miles at the moment, previous owner spent about 4 grand on it mid-2013 replacing seals, timing belt, full service. I think there's a new OE oil pump in there as well.
Runs great, no leaks at all. I've got a TDI 5 speed I'll be swapping in its place. |
Originally Posted by Baumeister
(Post 24633636)
