Jack stand mounting points... spot #1 or spot #2?
Spot # 1
This is near the cat. I was thinking a jack stand could go length-wise up in there (not across).
<img SRC="http://filebox.vt.edu/users/mbevels/Audi/New%20Pics/DSCN0741.JPG">
or Spot # 2
Not sure if it would be safe going up along the side of that welded lip. And I didn't want to go across the lip because it might bend.
<img SRC="http://filebox.vt.edu/users/mbevels/Audi/New%20Pics/DSCN0739.JPG">
OR is there an even better spot? I just want to start doing my own oil changes again.
Mike
or Spot # 2
Mike
NOT #2! i put my jacks on the frame structure just inside of the control arms inline with the rear
of the oil pan.
#1 i believe are the jack-points for when you haveta use the sh*tty OE accordian jack in your trunk
AudiWorld Expert
Get some Rhino ramps - <$30 at Walmart or go the route I did (edited)
<center><img src="http://pictureposter.audiworld.com/102/ramps.jpg"></center><p>
These ramps pictured here were offered by Preferred Living - but I checked their website and they no longer had them. They were $189
They are all steel and are very easy to use
