Need location of Power window/sunroof relay (Emergency!)
To make a long story short. My power windows do not work, nor does my sunroof. To make matters worse, my driver's side window is stuck in the down position and there's a blizzard going on outside! I removed the driver's side kick panel and exposed the auxillary relay/fuse panel. Every once in a while I can hear a click coming from one of the relays, but I can't tell which one it is. I don't have my Bentley on me, does anyone know the location of the Window/sunroof relay?
TIA!
TIA!
The relay can be jumped or operated manually ;o)
Mine died several months ago. I had to get another relay. In the mean time I figured out how it worked & manually operated the relay contacts to allow my windows & sunroof to function while awaiting the new relay to arrive.
Then jumper-wired it for better control.
Re: The relay can be jumped or operated manually ;o)
Care to share your secrets?
I just want to get my window up and then start looking for a new relay at the junk yard. The dealer wants $200 for a new one and for me to wait for a week for delivery!
Well, I would need to sit down again with the relay, to give you the actual pins to jumper.
As it was sometime ago I performed the mod.
Currently I do not have a spare relay, and I'm away from home for several days. ;o)
Any electrical troubleshooting skills? :O)
Ok, fixed the problem!
I pulled the control module and then removed it from it's casing. I took a look at the board through a microscope and found an open solder. I resoldered it and plugged it back in. Windows and power roof work like a charm. :-D
Windows/Sunroof not operational
Connie
S4Patrick
08-02-2009 01:36 PM
S4Patrick
08-02-2009 01:27 PM
MnAudi90CS
12
09-24-2007 09:36 AM
12V A4 Phil
06-22-2003 05:30 PM
