Oil fouled plug, oil in cylinder, valve seals?
I was playing around today again with the CQ, and found that the #5 plug I thought had gas on it from a leaky injector was actually oil. Upon looking down the plug well, I could see #5 had oil/oil residue at the bottom, while the other cylinders did not. The oil on the plug is on the lower half of the threads (cylinder side), and on the tip, which looks pretty black and fouled to me.
I know my valve seals aren't perfect, I get a puff of blue smoke now and then. Would this be the problem, or something else?
They "can" be done with the heads on...
It envolves pressurizing the cylinder and locking the engine in TDC for each cylinder to keep the valve from dropping. Generally, I take the heads off, this way you can deck them, re-lap the valves, and do headgaskets all in one shebang. Doing the "head-on" method can be troublesome because the valve keepers are often stuck and the valve needs to be whacked good with a deadblow hammer to get them loose. I generally put a folded towell under the head on the bench to keep the valve snug and do this. I've only done one "on car" valve seal job and that was a GM 4.3 - or 2.8, I don't remember - something in a GMC Jimmy. Anyways, there's your options.
Yup. Hit it all if you plan on keeping it. No better time.
If you DIY everything. Seals, lifters, gaskets, timing belt, WP, your looking at no more than 300-350.00 in parts and machine work and a ton of labor time - but then EVERYTHING is done.
Rendyx. Im doing the valve seals on my 2.8 v6 2v either this week or next week.
Im leaving the heads on to try and save some labor time and costs. Ill let you know how everythign turns out if you do the vale seals with the head on the car. It requires a lot of special tools, but i think it'll be worth it in the amount of time it saves. Im hoping to have everything done in one day!!! Who knows though. Im replacing waterpump,timing belt, timing belt roller, timing belt tensioner,valve seals,valve cover gaskets,camshaft seals. I'd like to do lifters while Im at it but I can't afford that at the moment. They are somewhere in the ballpark of 10-12 each. I also need a direct fit catalytic converter, and a new cv joint. Muffler shops around here want 250 to weld in a universal cat when i can get a direct fit for 260. I'd rather do work myself. Ill keep in touch tho and tell you how it goes after i complete this project.
One more thing. I am burning oil and I thought my piston rings were bad, but after ocmpression test.
the numbers came back and each were around 190-200 with one cyl at 150. I was relieved that the rings were still somewhat good. Just remember to hold the throttle fully open when your cranking the engine. Just a reminder
do I have to clean PCV valve if its clogged by oil? or is it something wrong if oil is in PCV valve?
S4AVT
03-28-2006 12:24 PM
wasya152
12-30-2003 05:57 PM
Innovator
07-21-2000 10:45 PM
