oil sender
oil sender
ok on the passenger side of the block, I have what seems to be a oil pressure sender, but underneath that sender there is another, that has a single wire, what is this one for? oil temp, pressure.. I have oil temp and pressure gauges, but Im not sure which is what? The sinlge wire sender is leaking oil and i'd like to replace it. Any tricks to get down there? What tools do you use to get at it without removing the radiator? I've tried, can not get at it.
Thanks,
Anthony '89 90Q
Thanks,
Anthony '89 90Q
Re: oil sender
<center><img src="http://pictureposter.audiworld.com/70023/oil_pressure_sensors.jpg"></center><p>oil pressure sender is on right...temp sensor on left (of pic)
if memory serves me correct...this is all on the top section of the oil pan on the DRIVERS side
update on location of unit....
<center><img src="http://pictureposter.audiworld.com/70023/v6block1.jpg"></center><p>
right there.....so i was wrong on the left sensor
red arrows are oil temp sensor
ok my engine is a little bit different 10V B3
mine are on the block, but at least I know the signal wire is for the warning light. I'll buy that one. Anyone with a 10V know how to get at that without removing the radiator?
Anthony '89 90Q 210K
Libtek13
08-04-2004 09:45 AM
audiquatro75
Audi Original "S" Cars
02-04-2004 05:12 PM
