quattro
quattro
Engine power is transmitted to the self locking Torsen center differential, and from there directly to the front axle differential and, by way of a drive shaft, to the rear axle differential.
When a vehicle is going around a corner, the outside wheels turn faster than the inside ones. To compensate for the difference, a differential gear is installed in the drive axles.
To compensate for the movement of the wheels on the front and rear axles, the Audi quattro has an additional center differential.
If one wheel should start to slip and begin to lose traction, a differential will only transmit a small amount of power to the other wheel that is not spinning. On the Audi quattro, this unwanted differential effect will be counteracted automatically by the self-locking Torsen center differential between forn tand rear axles, and the engine power will be transmitted to the wheels with the better traction.
Welcome home!
Emissions testing every other year. Saftey every year. not too sure about registration. i bought & registeredit last year and the sticker says '04 on my plate.
local3
02-22-2010 08:13 PM
AutoUnionQ7
Q7 MK 1 Discussion
01-27-2008 07:26 PM
DaBrosch
12
11-06-2006 12:23 PM
Liam in Montreal
08-03-2000 09:08 AM
