quick question re:ISV
(post SEARCH FUNCTION)
need to get TB or brake cleaner, i know... for now however <img src="http://pictureposter.audiworld.com/80971/quest.jpg"> |
use carb cleaner... don't let fluid sit in there... let it dry completely before re-installing
but is this safe or potnetially harmful?
i cant get the carb cleaner until i get the car running...
its a petroleum solvent... |
I'd say use only carb cleaner
ok....THANK YOU!
btw... not to second guess you but
one of the posts i read from the past suggested that carb cleaner had the ability to melt plastic, whereas brake cleaner and/or TB cleaner did not.
food for thought |
engine degreaser= not good idea>
you are usally supposed to wash it off with water, I think. Probably not a good idea. Just did mine with the brake cleaner today, and what a difference it makes!! :-)
probl;em solved.... thanx guys! used "snap" carb cleaner
(took my chances and drove my other broken down car to LAPS and made it.
True - and your ISV is metal where the carb cleaner should go.
ok cool
