Replacing lifters; broke one of the aluminum bearing caps!! ;-(
I just did a search and see that the aluminum caps might be fitted to each head individually. The good thing is however, that I didnt break it in the center, it broke on the edge where the nut holds it down, so maybe I can fix it. I hope so!! If not I may have a baaad day?
How did you break that??
Btw, they are all the same from the factory but what happens over time is your cam sets sort of a pattern/shape into them and thus people say they are "car specific". If its just one I would say go get a new one - don't try to fix it.
cam tower journals are "align-bored/honed" under torque while mated to head...
There is almost zero chance of another cap working or repairing one. Anyone can try any number of methods but I'd be looking for a new head.
And if you attempt saving/repairing the cap or replacing it with the same "number" cap off a different head I'd invest in a couple packages of Plasti-Guage strips as you're gonna be plasti-guaging yer *** off trying to get the right gauge compression and in the end chuck it all and go looking for another head anyway.
Only takes one journal to be .0001"-.0005" out of spec either tight, loose or eccentric and you're in deeper cah-cah than you ever thought possible if it lets go or seizes upwards of 4k RPMs.
Take it to a performace engine building shop and see if they can repair it
They may be able to weld the cracked area. They will also have to check to clearance to the cam to make sure the heat from welding didn't warp the cap. If it is warped you will have to have the cam journals align bored.
You may be better off getting a new cap and having the cam journals bored. I can't imagine that the only way to fix it is to replace the head, but if you can find a used head at a decent price that may be the cheapest way to go. Precision machine work can get expensive.
You can not just slap on a used cap from another head or location. The caps are machined on the head and that makes each one unique and non-interchangable.
I broke my #2 cam cap and I raided a NF engine for more.. I do not recommend
doing so unless you know what you're doing exactly and precise measurements. Cap from another engine could be off enough to not being able to tighten down and break it again. Only reason i went this way is because I was very poor and couldn't afford a head, also I have a spare cam so if anything happens, it's not going to cost me extra.
it took me a good 5 hours to sand/polish the cap close enough to where i feel "confident" to replace the original line-bored cap.
on a positive note, it costed me $10 and 30k miles later it's running perfect.
"align-boring/honing" means boring/honing multiple bores on a single/common axis....
to exactly the same ID. Once thats done how do you "re" align-hone or bore all those cam journals to an even larger ID than they came with and have them fit the cam journals which havent gotten any bigger? You can neither bore nor hone anything, including bore journals, without removing metal. Remove metal from the I.D. of "anything" and its bore gets bigger/larger. However the mating journals on the camshaft cant "grow" a corresponding amount. So if you realign hone you've got larger ID journals but the bearing journals on the cam have not grown. Recipe for disaster.
Unless someones found a way to "reverse bore/hone" and make IDs smaller he's locked into a new head as the "safest/most cost-effective" alternative.
