So I put the Eibach Prokit on today... ugh
Well, I'm pretty happy with it so far (just drove it home since the install). I had the factory "sport" suspension which was already pretty low.. . now the front seems lower, but the rear doesn't seem much lower at all, maybe it just needs time to settle.
How much lower was the audi "sport" suspension than the "regular" suspension?
AND NOW I JUST READ THIS from 20v.org!!!!!
"** Beware that the Eibach springs are linear in the front and progressive in the rear. This is opposite from what you might expect, so be sure your installer knows which ones go one which end. "
STUPID LIFE! I put the progressive springs on the FRONT, like a "normal" car!!!
what effect does this have? would it have to do w/ why it didn't lower the rear that much(they are suppose to lower the car "1.4 all around from the "regular" stock set-up.).
I just installed these w/ the stock dampers for now (till I can afford the bilstein sports next month), so I'm going to switch the springs around when I get the bilsteins.
Answers please
Answers please
Re: So I put the Eibach Prokit on today... ugh
I'd rather have linear springs at all four corners (oh wait, I DO! ). I think you'll be happier with the handling and such with the linears up front.
The 1BE package lowered the car 20mm and added stiffer dampers.
Springs do need to settle, but I'd still switch the correct springs on the correct end...
The springs are the same length, but the spring rate of the progressive is higher.
Yeah, I'm going to change it the right way as soon as I get those bilsteins!
Thanks for the info Eric!
shehatezme
08-24-2003 09:13 PM
Pick up the car from Eibach this evening. I don't have a hard copy of everything they did but I'm...
V8 GECKO
08-09-2003 10:20 PM
cpayne
10-29-2000 05:37 PM
