want 5 bolt pattern
does anyone know if i can do a 5 lug conversion on my 4 bolt 90s?
FWD or AWD, and year are required before that question can be answered
Re: FWD or AWD, and year are required before that question can be answered
it is a 93 90s, fwd,2.8 v6,4 door automatic. but it is getting a tranny swap from auto to manual
For the front you will need S2 hubs at the very least and most likely the rotors unless you can figure out how to redrill yours and if there is room. I have never looked but I am sure somebody here has.
On the 2wd in the rear its very easy and cheap. Just find a 5000T 2wd at the junkyard and get the hubs and rotors from that. If you look on sites that sell the conversion you will see that its not cheap but it is very easy with the correct parts. Jasin S2 look saloon |
what if?
you said all i had to do was get the hubs and rotors for my car. what if i wanted to put on a big brake kit with that? would i have to buy a universal kit and do the modifications? food for thought.
Re: what if?
You would still need the hubs. I was thinking of going to 2 peice rotors when my S2 ones wear out cause they are cheaper and readily available.
i appreciate the help
i appreciate the help. now any thoughts on how to turbocharge my v6 2.8?
