Mill Lane |
10-04-2018 01:15 PM |
A1clock spring nightmare!!!
Hi, I'm hoping someone here might be able to shed some light on this problem I'm having after replacing a clock spring on a customers 2011 A1 (8X0)
Its the first time I've used VCDS but after reading up in detail I think I did it correctly but now I've got more faults than when I started.
Initial scan:
Code:
Thursday,30,August,2018,12:29:24:47119
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ8X5CB022228 License Plate: JODIE 1
Mileage: 55980km-34784mi Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 5F
VIN: WAUZZZ8X5CB022228 Mileage: 55980km-34784miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP
Component: R4 1.6l TDI H63 9978
Revision: --H63--- Serial number:
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
ROD: EV_ECM16TDI02103L906023KG.rod
VCID: 7F580ABAE776FC0F220-802A
1 Fault Found:
7609 - Control Module 1 for Coolant Fan
P1946 00 [101] - Defective
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 36262 km
Date: 2017.01.25
Time: 14:14:14
Engine speed: 1982.75 /min
Normed load value: 33.7 %
Vehicle speed: 106 km/h
Coolant temperature: 96 °C
Intake air temperature: 15 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.456 V
Unlearning counter according OBD: 40
Sensor for temp after charge air cooler: raw value-TBA_MES: 15 °C
Sensor for engine block temperature: raw value-Coolant temperature: 96 °C
Coolant temperature at radiator outlet: actual value-TCO_2: 95 °C
Outside air temperature-Ambient temperature: 8.25 °C
Ambient air pressure-Ambient pressure: 1013.58 hPa
Coolant fan 1: activation-Radiator fan 1: activation: 17.2 %
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 330448E9436F00B4CC2712E4C2D900920C00
Shop #: WSC 00046 000 00000
VCID: 7F580ABAE7B6FC0F220-802A
No fault code found.
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030005470664
VCID: 343215969230EF578F2-8060
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
Component: BCM PQ35 M 110 0655
Revision: 00110 AE
Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045
VCID: 40DA4946DA8843F71BA-8014
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 254
Reset counter: 47
Mileage: 40118 km
Time Indication: 0
Date: 2017.11.02
Time: 19:02:42
Freeze Frame:
Term 15 On
Voltage: 14.35 V
ON
ON
Term 50 On
OFF
OFF
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
Component: Airbag10.41 H04 0008
Revision: -------- Serial number: 003JJ002XTZB
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001015
ROD: EV_Airba1041BPAAU210.rod
VCID: 48CA5166F2387BB7D3A-801C
Crash sensor for side airbag: driver side:
Serial number: 3554VRB405V0K4DICPCF
Crash sensor for side airbag: front passenger side:
Serial number: 3575HRB40570N3MG5O7J
Crash sensor for front airbag: driver side:
Serial number: 3585HRB40590N3MGCGJX
Rear Impact Crash Sensor:
Serial number: 3515ZRB40610IAMCC92B
1 Fault Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 51743 km
Date: 2018.06.03
Time: 15:00:43
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 B HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010016 Serial number: 20110729200828
Coding: 1184004000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 392C24A2B9D2123F5C4-806C
1 Fault Found:
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 106
Mileage: 51743 km
Date: 2018.06.03
Time: 15:00:41
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb
Part No SW: 8X0 920 980 D HW: 8X0 920 980 D
Component: KOMBI_MEDIUM H03 0179
Serial number: 00000000000000
Coding: 41DE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 40DA4946DA0843F71BA-8014
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 A HW: 8U0 907 468 A
Component: GAT 4CAN 1L M H10 0044
Revision: 1P040023 Serial number: 2341P1172101BE
Coding: FBCF005A000100010153
Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H
Component: J367-BDM H07 0171
Serial number: 00000000007100802462
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H18 0018
Serial number: 10061100000000000091
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H03 0179
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 D HW: 8X0 959 793 D
Component: TSG FA H09 0409
Revision: -------- Serial number: --------------
Coding: 011E02200101000100
VCID: 4EC6677E10DCA587996-801A
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F381AFA7E56CC8FF20-807A
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 8X0 035 223 C HW: 8X0 035 223 B
Component: BOSE G3 A1Q3 H04 0130
Revision: CK004200 Serial number: 00000000001521
Coding: 010000
VCID: 323E138E6424E1679DE-8066
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 D HW: 8X0 959 792 D
Component: TSG BF H09 0409
VCID: 4DC460721DDA9E9FE0C-8018
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8X0 035 193 E HW: 8X0 035 193 C
Component: RMC Cnct Nav H51 0775
Coding: 01010000008051070023000103020100000000
VCID: 3A2E3BAEBC54192755E-806E
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
Serial number: 9462HQ0B0126704
End----------(Elapsed Time: 01:04, VBatt start/end: 12.0V/12.1V)-----------
this and reading up on other similar problems led me to diagnose the clock spring as the issue, replaced and coded which resulted in:
Code:
Tuesday,02,October,2018,16:56:40:47119
www.Ross-Tech.com
VIN: WAUZZZ8X5CB022228 License Plate: JODIE2
Mileage: 56930km-35374mi Repair Order:
VIN: WAUZZZ8X5CB022228 Mileage: 56930km-35374miles
03-ABS Brakes -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 36262 km
Date: 2017.01.25
Time: 14:14:14
Revision: --------
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 2
Reset counter: 48
Mileage: 56935 km
Time Indication: 0
Date: 2018.10.02
Time: 00:02:54
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1051
Hex Value: 0x1B87
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Revision: 00110 AE
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 55
Mileage: 40118 km
Time Indication: 0
Date: 2017.11.02
Time: 19:02:42
Freeze Frame:
Term 15 On
Voltage: 14.35 V
ON
ON
Term 50 On
OFF
OFF
1 Fault Found:
B1000 1B [136] - Resistance Too High
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 51743 km
Date: 2018.06.03
Time: 15:00:43
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20180415200305
Coding: 1184004000
Shop #: WSC 01286 386 08256
VCID: 025E834E948491E74DE-8056
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H07 0009
Serial number: 31 03 2011 11122738
13 Faults Found:
0516 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 48
Mileage: 56935 km
Date: 2018.10.02
Time: 00:02:59
147462 - Terminal 15
B1148 12 [009] - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
226827 - Turn Signal Switch
B1144 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
226839 - Turn Signal Switch
B1144 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 48
227339 - Windshield Wiper Switch
B1145 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
227355 - Windshield Wiper/Washer Switch
B1149 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 88
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
332660 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 88
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
U108E 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
617736 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
UBat: 13.10 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Coding: 41DE00
Serial number:
Coding: 000002
Coding: 11251
Shop #: WSC 00046
Coding: 010000
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 56556 km
Time Indication: 0
Date: 2018.09.15
Time: 02:31:45
End----------(Elapsed Time: 00:59, VBatt start/end: 12.2V/12.2V)-----------
not what i needed!!!! after calming down from the panic that my first coding job had cost me £250 I've sort of got my head round VCDS coding and think I did what i was supposed to??
what i don't understand and think this is where the problem lies is in the first scan the fault is registered with Part No: SW: 8X0 953 501 B (switch stalks) HW: 5K0 953 569 H (clock spring)
in the second scan:
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL (part no of the replacement clock spring)
I've come to the conclusion that perhaps the clock spring originally came as part of the switch stalk assembly and is the only programmable part of that joint assembly, is that correct??
Am I missing something? I read somewhere something about dealer codes but to be honest its all very alien to me, Ive tried posting on the rosstech forum but noones offered me a possible solution.
Ive used a genuine part and licensed copy of VCDS
I've done continuity tests on both units and the original clock spring definitely has a fault
thanks for your time, I hope someone can help..........
