A1clock spring nightmare!!!
Hi, I'm hoping someone here might be able to shed some light on this problem I'm having after replacing a clock spring on a customers 2011 A1 (8X0)
Its the first time I've used VCDS but after reading up in detail I think I did it correctly but now I've got more faults than when I started.
Initial scan:
this and reading up on other similar problems led me to diagnose the clock spring as the issue, replaced and coded which resulted in:
not what i needed!!!! after calming down from the panic that my first coding job had cost me £250 I've sort of got my head round VCDS coding and think I did what i was supposed to??
what i don't understand and think this is where the problem lies is in the first scan the fault is registered with Part No: SW: 8X0 953 501 B (switch stalks) HW: 5K0 953 569 H (clock spring)
in the second scan:
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL (part no of the replacement clock spring)
I've come to the conclusion that perhaps the clock spring originally came as part of the switch stalk assembly and is the only programmable part of that joint assembly, is that correct??
Am I missing something? I read somewhere something about dealer codes but to be honest its all very alien to me, Ive tried posting on the rosstech forum but noones offered me a possible solution.
Ive used a genuine part and licensed copy of VCDS
I've done continuity tests on both units and the original clock spring definitely has a fault
thanks for your time, I hope someone can help..........
Initial scan:
Code:
Thursday,30,August,2018,12:29:24:47119 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: WAUZZZ8X5CB022228 License Plate: JODIE 1 Mileage: 55980km-34784mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8X-AU21 (8U0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 5F VIN: WAUZZZ8X5CB022228 Mileage: 55980km-34784miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP Component: R4 1.6l TDI H63 9978 Revision: --H63--- Serial number: Coding: 00114016030501080000 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015 ROD: EV_ECM16TDI02103L906023KG.rod VCID: 7F580ABAE776FC0F220-802A 1 Fault Found: 7609 - Control Module 1 for Coolant Fan P1946 00 [101] - Defective Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 36262 km Date: 2017.01.25 Time: 14:14:14 Engine speed: 1982.75 /min Normed load value: 33.7 % Vehicle speed: 106 km/h Coolant temperature: 96 °C Intake air temperature: 15 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 14.456 V Unlearning counter according OBD: 40 Vehicle speed: 106 km/h Sensor for temp after charge air cooler: raw value-TBA_MES: 15 °C Sensor for engine block temperature: raw value-Coolant temperature: 96 °C Coolant temperature at radiator outlet: actual value-TCO_2: 95 °C Outside air temperature-Ambient temperature: 8.25 °C Ambient air pressure-Ambient pressure: 1013.58 hPa Coolant fan 1: activation-Radiator fan 1: activation: 17.2 % Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH Component: ESP8.2i front H07 0001 Revision: -------- Coding: 330448E9436F00B4CC2712E4C2D900920C00 Shop #: WSC 00046 000 00000 VCID: 7F580ABAE7B6FC0F220-802A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 8X0 820 045 A HW: 8X0 820 045 A Component: J255 Klima Manuell 0140 Revision: 0000707S Serial number: 03030005470664 Shop #: WSC 00046 000 00000 VCID: 343215969230EF578F2-8060 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb Part No SW: 8X0 907 063 G HW: 8X0 907 063 G Component: BCM PQ35 M 110 0655 Revision: 00110 AE Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045 Shop #: WSC 00046 000 00000 VCID: 40DA4946DA8843F71BA-8014 Subsystem 1 - Part No: 8X0 951 177 Component: DWA-Sensor H0 H01 0020 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 1 Fault Found: 01502 - Bulb for Rear Fog; Left (L46) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 254 Reset counter: 47 Mileage: 40118 km Time Indication: 0 Date: 2017.11.02 Time: 19:02:42 Freeze Frame: Term 15 On Voltage: 14.35 V ON ON Term 50 On OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8X0-959-655.clb Part No SW: 8X0 959 655 A HW: 8X0 959 655 A Component: Airbag10.41 H04 0008 Revision: -------- Serial number: 003JJ002XTZB Coding: 30314539303330303034554A305238583053 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_Airba1041BPAAU210 001015 ROD: EV_Airba1041BPAAU210.rod VCID: 48CA5166F2387BB7D3A-801C Crash sensor for side airbag: driver side: Serial number: 3554VRB405V0K4DICPCF Crash sensor for side airbag: front passenger side: Serial number: 3575HRB40570N3MG5O7J Crash sensor for front airbag: driver side: Serial number: 3585HRB40590N3MGCGJX Rear Impact Crash Sensor: Serial number: 3515ZRB40610IAMCC92B 1 Fault Found: 9437211 - Igniter for Driver's Airbag B1000 1B [137] - Resistance Too High MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 51743 km Date: 2018.06.03 Time: 15:00:43 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb Part No SW: 8X0 953 501 B HW: 5K0 953 569 H Component: LENKS.MODUL 014 0140 Revision: FF010016 Serial number: 20110729200828 Coding: 1184004000 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 392C24A2B9D2123F5C4-806C 1 Fault Found: 365080 - Controls in Steering Wheel U108E 00 [009] - No Communications Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 106 Mileage: 51743 km Date: 2018.06.03 Time: 15:00:41 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb Part No SW: 8X0 920 980 D HW: 8X0 920 980 D Component: KOMBI_MEDIUM H03 0179 Serial number: 00000000000000 Coding: 41DE00 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390 ROD: EV_Kombi_UDS_VDD_AU10.rod VCID: 40DA4946DA0843F71BA-8014 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb Part No SW: 8U0 907 468 A HW: 8U0 907 468 A Component: GAT 4CAN 1L M H10 0044 Revision: 1P040023 Serial number: 2341P1172101BE Coding: FBCF005A000100010153 Shop #: WSC 00046 000 00000 VCID: 40DA4946DA8843F71BA-8014 Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H Component: J367-BDM H07 0171 Serial number: 00000000007100802462 Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 Component: J532_DCDCStab H18 0018 Serial number: 10061100000000000091 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 8X0 920 980 D HW: 8X0 920 980 D Component: IMMO H03 0179 Serial number: Coding: 000002 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110 ROD: EV_Immo_UDS_VDD_AU10.rod VCID: 40DA4946DA0843F71BA-8014 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb Part No SW: 8X0 959 793 D HW: 8X0 959 793 D Component: TSG FA H09 0409 Revision: -------- Serial number: -------------- Coding: 011E02200101000100 Shop #: WSC 00046 000 00000 VCID: 4EC6677E10DCA587996-801A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11251 Shop #: WSC 00046 VCID: 2F381AFA7E56CC8FF20-807A No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: Redir Fail! Part No SW: 8X0 035 223 C HW: 8X0 035 223 B Component: BOSE G3 A1Q3 H04 0130 Revision: CK004200 Serial number: 00000000001521 Coding: 010000 Shop #: WSC 00046 000 00000 VCID: 323E138E6424E1679DE-8066 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb Part No SW: 8X0 959 792 D HW: 8X0 959 792 D Component: TSG BF H09 0409 Revision: -------- Serial number: -------------- Coding: 011E02200101000100 Shop #: WSC 00046 000 00000 VCID: 4DC460721DDA9E9FE0C-8018 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: None Part No SW: 8X0 035 193 E HW: 8X0 035 193 C Component: RMC Cnct Nav H51 0775 Coding: 01010000008051070023000103020100000000 Shop #: WSC 00046 000 00000 VCID: 3A2E3BAEBC54192755E-806E Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603 Component: DU6 Basic H42 0084 Serial number: 9462HQ0B0126704 No fault code found. End----------(Elapsed Time: 01:04, VBatt start/end: 12.0V/12.1V)-----------
Code:
Tuesday,02,October,2018,16:56:40:47119 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: WAUZZZ8X5CB022228 License Plate: JODIE2 Mileage: 56930km-35374mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8X-AU21 (8U0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 5F VIN: WAUZZZ8X5CB022228 Mileage: 56930km-35374miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 5F-Information Electr. -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP Component: R4 1.6l TDI H63 9978 Revision: --H63--- Serial number: Coding: 00114016030501080000 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015 ROD: EV_ECM16TDI02103L906023KG.rod VCID: 7F580ABAE776FC0F220-802A 1 Fault Found: 7609 - Control Module 1 for Coolant Fan P1946 00 [101] - Defective Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 36262 km Date: 2017.01.25 Time: 14:14:14 Engine speed: 1982.75 /min Normed load value: 33.7 % Vehicle speed: 106 km/h Coolant temperature: 96 °C Intake air temperature: 15 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 14.456 V Unlearning counter according OBD: 40 Vehicle speed: 106 km/h Sensor for temp after charge air cooler: raw value-TBA_MES: 15 °C Sensor for engine block temperature: raw value-Coolant temperature: 96 °C Coolant temperature at radiator outlet: actual value-TCO_2: 95 °C Outside air temperature-Ambient temperature: 8.25 °C Ambient air pressure-Ambient pressure: 1013.58 hPa Coolant fan 1: activation-Radiator fan 1: activation: 17.2 % Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH Component: ESP8.2i front H07 0001 Revision: -------- Coding: 330448E9436F00B4CC2712E4C2D900920C00 Shop #: WSC 00046 000 00000 VCID: 7F580ABAE7B6FC0F220-802A 1 Fault Found: 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 0 Fault Frequency: 2 Reset counter: 48 Mileage: 56935 km Time Indication: 0 Date: 2018.10.02 Time: 00:02:54 Freeze Frame: Hex Value: 0x0007 Hex Value: 0x0002 Hex Value: 0x1051 Hex Value: 0x1B87 Hex Value: 0x00FF Hex Value: 0x7F7F Hex Value: 0x7F00 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 8X0 820 045 A HW: 8X0 820 045 A Component: J255 Klima Manuell 0140 Revision: 0000707S Serial number: 03030005470664 Shop #: WSC 00046 000 00000 VCID: 343215969230EF578F2-8060 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb Part No SW: 8X0 907 063 G HW: 8X0 907 063 G Component: BCM PQ35 M 110 0655 Revision: 00110 AE Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045 Shop #: WSC 00046 000 00000 VCID: 40DA4946DA8843F71BA-8014 Subsystem 1 - Part No: 8X0 951 177 Component: DWA-Sensor H0 H01 0020 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 1 Fault Found: 01502 - Bulb for Rear Fog; Left (L46) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 254 Reset counter: 55 Mileage: 40118 km Time Indication: 0 Date: 2017.11.02 Time: 19:02:42 Freeze Frame: Term 15 On Voltage: 14.35 V ON ON Term 50 On OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8X0-959-655.clb Part No SW: 8X0 959 655 A HW: 8X0 959 655 A Component: Airbag10.41 H04 0008 Revision: -------- Serial number: 003JJ002XTZB Coding: 30314539303330303034554A305238583053 Shop #: WSC 00046 000 00000 ASAM Dataset: EV_Airba1041BPAAU210 001015 ROD: EV_Airba1041BPAAU210.rod VCID: 48CA5166F2387BB7D3A-801C Crash sensor for side airbag: driver side: Serial number: 3554VRB405V0K4DICPCF Crash sensor for side airbag: front passenger side: Serial number: 3575HRB40570N3MG5O7J Crash sensor for front airbag: driver side: Serial number: 3585HRB40590N3MGCGJX Rear Impact Crash Sensor: Serial number: 3515ZRB40610IAMCC92B 1 Fault Found: 9437211 - Igniter for Driver's Airbag B1000 1B [136] - Resistance Too High MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 51743 km Date: 2018.06.03 Time: 15:00:43 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL Component: LENKS.MODUL 016 0180 Revision: --X01--- Serial number: 20180415200305 Coding: 1184004000 Shop #: WSC 01286 386 08256 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 025E834E948491E74DE-8056 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C Component: E221 - MFL H07 0009 Serial number: 31 03 2011 11122738 13 Faults Found: 0516 - Databus U1121 00 [009] - Missing Message Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 48 Mileage: 56935 km Date: 2018.10.02 Time: 00:02:59 147462 - Terminal 15 B1148 12 [009] - Short to Plus Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 226827 - Turn Signal Switch B1144 13 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 6 226839 - Turn Signal Switch B1144 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 48 227339 - Windshield Wiper Switch B1145 13 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 5 227355 - Windshield Wiper/Washer Switch B1149 13 [008] - Open Circuit Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 9 Reset counter: 88 229127 - Cruise Control Switch B1154 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 229147 - Cruise Control Switch B1154 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 332660 - Databus U1121 00 [008] - Missing Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 88 342020 - Comfort System CAN Bus (SAE Medium Speed Bus) U0011 00 [008] - Performance Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 365080 - Controls in Steering Wheel U108E 00 [008] - No Communications Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 2 617736 - Selector Lever Park Position Lock Switch B1162 29 [008] - Signal Implausible Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 1140738 - Steering angle sensor B1168 54 [009] - Missing Calibration / Basic Setting Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 UBat: 13.10 V MC1 interner Fehlercode: 0 MC2 interner Fehlercode: 0 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb Part No SW: 8X0 920 980 D HW: 8X0 920 980 D Component: KOMBI_MEDIUM H03 0179 Serial number: 00000000000000 Coding: 41DE00 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390 ROD: EV_Kombi_UDS_VDD_AU10.rod VCID: 40DA4946DA0843F71BA-8014 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb Part No SW: 8U0 907 468 A HW: 8U0 907 468 A Component: GAT 4CAN 1L M H10 0044 Revision: 1P040023 Serial number: 2341P1172101BE Coding: FBCF005A000100010153 Shop #: WSC 00046 000 00000 VCID: 40DA4946DA8843F71BA-8014 Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H Component: J367-BDM H07 0171 Serial number: 00000000007100802462 Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 Component: J532_DCDCStab H18 0018 Serial number: 10061100000000000091 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 8X0 920 980 D HW: 8X0 920 980 D Component: IMMO H03 0179 Serial number: Coding: 000002 Shop #: WSC 00046 790 00000 ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110 ROD: EV_Immo_UDS_VDD_AU10.rod VCID: 40DA4946DA0843F71BA-8014 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb Part No SW: 8X0 959 793 D HW: 8X0 959 793 D Component: TSG FA H09 0409 Revision: -------- Serial number: -------------- Coding: 011E02200101000100 Shop #: WSC 00046 000 00000 VCID: 4EC6677E10DCA587996-801A No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11251 Shop #: WSC 00046 VCID: 2F381AFA7E56CC8FF20-807A No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: Redir Fail! Part No SW: 8X0 035 223 C HW: 8X0 035 223 B Component: BOSE G3 A1Q3 H04 0130 Revision: CK004200 Serial number: 00000000001521 Coding: 010000 Shop #: WSC 00046 000 00000 VCID: 323E138E6424E1679DE-8066 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb Part No SW: 8X0 959 792 D HW: 8X0 959 792 D Component: TSG BF H09 0409 Revision: -------- Serial number: -------------- Coding: 011E02200101000100 Shop #: WSC 00046 000 00000 VCID: 4DC460721DDA9E9FE0C-8018 1 Fault Found: 02111 - Motor for Window Regulator 005 - No or Incorrect Basic Setting / Adaptation - Intermittent Freeze Frame: Fault Status: 00100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 71 Mileage: 56556 km Time Indication: 0 Date: 2018.09.15 Time: 02:31:45 ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: None Part No SW: 8X0 035 193 E HW: 8X0 035 193 C Component: RMC Cnct Nav H51 0775 Coding: 01010000008051070023000103020100000000 Shop #: WSC 00046 000 00000 VCID: 3A2E3BAEBC54192755E-806E Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603 Component: DU6 Basic H42 0084 Serial number: 9462HQ0B0126704 No fault code found. End----------(Elapsed Time: 00:59, VBatt start/end: 12.2V/12.2V)-----------
in the second scan:
kingcezar1992
A6 (C7 Platform) Discussion
13
03-05-2020 08:44 AM
