Body Control Module (right) fuse melted
Display says license bulb out (3 wks ago), then last week "left rear turn signal", then a dipped headlight, then right rear turn signal (all within a day). Got a bunch of replacement bulbs today. Started to replace brake & rear turn signal bulbs. The left 7507 still does not work. Opened fuse box and F16 Body Control Module (Right) fuse is burned to a point that entire box needs to be replaced. Car has CPO warranty for another 18 months. I know bulbs & fuses are excluded, but doesn't this sound like a BCM issue?
Side note: AutoZone has only an LED version of 6418 (license plate). Any issue with this or should I find OEM incandescent?
Taking to dealer tomorrow.
2012 A3 S3 Manual (currently at 48K)
Update needed for Body Control Module (Right) fuse melted
Hi, I have a 2012 A3 and I have experience the same issue with the melted F-16 30A fuse. What did the dealer do and is there a concern or a recall?
Thank you
Walter
Thank you
Walter
htko4316
01-31-2007 01:21 PM
TT-Square
01-30-2006 10:09 AM
FriscoS4
07-12-2005 06:42 AM
FrankS
11-28-2003 06:19 AM
