DSG preselect gear indicator. Useful? Possible?
The dash center display shows the currently-engaged gear.. If it also displayed the gear that's preselected, it might be useful in anticipating delays when the preselected gear is in the opposite direction you intend to pick..
Any ideas on whether or not the responsible controllers are flashable, and if anyone has the resources to reprogram it?
What would be cooler is that you could control what gear to pre-select.
One tap pre-selects the gear and the second click would change the gear like it is right now. Kind of like double click and single click on windows
Why bother?? Downshift delay is 600-900 ms. Barely the blink of an eye...
By the time you look at the display and perform whatever "analysis" of your potential gear selection and it's ramifications, you could just go ahead and change to whatever gear you want....
Exactly. These ideas give me a headache. How on earth are
you supposed to be watching the road when you're allegedly going to spend time analyzing what gear has been preselected, etc.
It's called "manual" tranny if you want that kind of control.
I can shift manual faster than time to perform function on my DSG
I don't buy that 600-900 ms stuff, unless that equates to .6 or .9 of a second--then I buy it.
Ok, try this test: Upshift or downshift using the paddle. Try to touch your shoulder/chest and get your hand back on the steering wheel after tapping the lever as fast as you can, and your hand will easily get back to the wheel before the shift occurs.
With a manual trans, I can perform the shift I WANT faster that that, and specifically WHEN I want!
Don't get me wrong, I love my DSG for daily use, but for ultimate performance work the manual trans seems the way to go for a competent driver. I am looking forward to track days real soon to get the REAL feeling of this DSG, not the on ramp feeling.
Re: Yes, 600 ms. = 600/1000 seconds = .6 seconds.
Yes, it's well known the upshift is a lot faster than the downshift with DSG. No matter how good you are with a manual, you will lose to DSG.
