Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
:: GruvenParts.com Performance Parts for Audi !
Old 12-13-2016, 07:57 PM
  #11
Former Vendor
gruvenparts.com's Avatar
24V Billet VR6 Drive Belt Pulleys - All 24V VR6
GruvenParts.com offers a complete set of ultra sleek lightweight 24V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 24V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys ARE NORMAL DRIVE (NOT UNDER-DRIVE). These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
Buy them as a set and save!
These pulleys replace the following OEM part numbers :
Crank Pulley : 022-105-243A (022105243A)
Tensioner Pulley: 022-145-299D (022145299D)
Water Pump Pulley: 021-121-031A (021121031A)
Alternator Pulley: 022-903-119A (022903119A) and 038-903-119B (038903119B)
Power Steering Pulley : 038-145-255A (038145255A)
Old 12-15-2016, 06:43 PM
  #12
Former Vendor
Billet / Carbon Fiber / ""VeeChain""
Pay homage to the unique VR6 engine design with this accurate CNC keychain minature. Measuring about 2 inches in length by 1 inch width, its an instant conversation starter with the girls at the parties who are constantly wondering about your 15 degree cylinder offset. This is an Oichan original design (Corrado - Oichan's Volkswagen Corrado VR6) sold under his permission. Beware of the rip off versions out there which are made using water jet process and have ragged edges and poor quality. Ours are made on a 3 axis CNC 1 at a time and are literally perfect replications of the unique VR6 engine.
Available in machine polished billet aluminum or genuine 3K weave carbon fiber plate.
Old 12-18-2016, 08:03 PM
  #13
Former Vendor
BPY Engine Upper Rad Hose Billet 4Y Fitting!
GruvenParts.com is happy to release our Billet Upper Radiator Hose 4Y Coolant Fittings for VW Golf/Jetta/Passat/EOS and Audi TT/A3 with BPY Engine -- P/N 1K0-121-087H (1K0121087H).
The OEM plastic 4Y connector used in the upper radiator hose is prone to cracking and leaking which often results in a rapid loss of coolant which can permanently damage your motor.
The GruvenParts.com billet 4Y Pipe is machined from Aircraft Grade 6061-T651 Aluminum, professionally TIG welded, and then pressure checked by our licensed welders. This one will permanently stop the nonsense caused by the VW/Audi cheap plastic coolant fitting.
This billet 4Y Pipe is intended to replace the plastic 4Y fitting OEM P/N 1K0-121-087H (1K0121087H) found in the upper radiator hose of the BPY Engine Code VW's and Audis :
VW EOS – 07-11
VW Jetta – 05-10
VW Golf – 06-12
VW Passat – 06-08
Audi A3 – 05-12
Audi TT – 07-12
Old 12-20-2016, 08:04 PM
  #14
Former Vendor
2.0T FSI BPY Engine Billet Pulleys!
GruvenParts.com is happy to announce our billet lightweight alternator and tensioner pulleys for the VW and Audi 2.0T FSI engines! Read at the end for the billet crank pulley that's coming soon!
Lightweight Billet Aluminum 2.0T BPY Engine Alternator Pulley
Ditch the super heavy 1 lb clutched alternator pulley on your 2.0T FSI in favor of this 125 gram billet aluminum version designed using high tech CAD software and crafted on one of our CNC's. Ours is precision CNC'd from 6061-T651 aluminum with a total runout of less than .001""! All this means a smoother and quiter engine that revs quicker off idle. Comes complete with high grade nut and thrust washer. Installs quick but please follow all Volkswagen/Audi installation instructions.
This part replaces OEM P/N 022-903-119C (022903119C) clutch-style(one-way) alternator pulley as well as P/N 038-903-119B (038903119B) solid alternator pulley and fits VW Golf, GTI, Jetta, EOS, Passat and Audi A3, TT with 2.0T FSI BPY Engine code. Please check your OEM part number and check the part interchangeability note at the end of this page.
Lightweight Billet Aluminum 2.0T BPY Engine Tensioner Pulley
Plastic may have made the bean counters at VW happy, but it has no business as a tensioner pulley on your high strung VW/Audi 2.0T FSI motor. Ours is extremely light weight and contains a precision 20K RPM SKF bearing that will perform more quietly and far outlast the OEM plastic pulley. Installation is a breeze – simply release belt tension, remove the tensioner pulley bolt, and swap ours in. Note - the torx bolt loosens counterclockwise (normal, right hand bolt). Please follow all Volkswagen/Audi installation instructions for installation.
This part replaces the pulley found the tensioner OEM P/N 06F-903-315 (06F903315) and fits VW Golf, GTI, Jetta, EOS, Passat and Audi A3, TT with 2.0T FSI BPY Engine code. Please check your OEM part number for verification before ordering!
Alternator Pulley Part Number Interchange Information
The GruvenParts.com billet lightweight 2.0T FSI BPY alternator pulley is designed to replace OEM P/N 022-903-119C (022903119C) clutch-style(one-way) alternator pulley as well as P/N 038-903-119B (038903119B). The following part numbers are also interchangeable :
022903119C ; 021903026A; 021903119G; 022-903-119-A; 022903028A; 022903119A; 028903030; 028903030A; 028903119AL; 028903119AM; 038-903-119-A; 038-903-119-T; 038903023K; 038903023L; 038903023Q; 038903023QX; 038903023R; 038903023RX; 038903024A; 038903024B; 038903024C; 038903024D; 038903024E; 038903024F; 038903024G; 038903119A; 038903119S; 038903119T; 03G903119; 03G903119A; 045903023; 045903023B; 045903023F
038903119B ; 028-903-119-2; 028903026H; 028903028C; 028903028CX; 028903028D; 030-903-119-D; 030903023H; 030903023J; 030903023L; 030903023LX; 030903119D; 036903024; 036903024A; 036903024AX; 036903024P; 036903026; 036903026A; 036903026B; 037903025E; 037903025EX; 037903025FX; 037903025J; 037903025K; 037903025Q; 037903025R; 037903026C; 06A903026; 06A903026A; 06A903026B; 06A903026C
022903119C ; 021903026A; 021903119G; 022-903-119-A; 022903028A; 022903119A; 028903030; 028903030A; 028903119AL; 028903119AM; 038-903-119-A; 038-903-119-T; 038903023Q; 038903023QX; 038903023RX; 038903024A; 038903024C; 038903024D
Billet Crank Pulley Pre-Buy
GruvenParts is happy to announce the Pre-Buy for the 2.0T FSI billet lightweight crank pulleys! If you want 1, please email Paul@GruvenParts.com.
2.0T FSI BPY Engine Billet Crank Pulley!
This billet crank pulley will reduce the rotating mass by approximately 2.4 lbs (1133 grams) and makes an excellent addition to our other 2.0T FSI engine pulleys.
The crank pulley is machined from aerospace grade 6061-T651 aluminum on one of our precision HAAS CNC mill lathes to a run out of less than .001"". The pulley includes the factory timing marks and exactly replicates the OEM pulley geometry (NOT under-drive).
We will begin manufacturing these once we have 10 pre-orders, so get on the list now by ordering in advance.
This part replaces OEM P/N 06F-105-243H (06F105243H), 06F-105-243J(06F105243J) VW and Audi Crank Pulleys and fits the following vehicles :
Volkswagen EOS, Golf, GTI, Jetta, and Passat with the BPY Engine Code 2.0T FSI motor.
Audi A3 and A4 with BPY Engine code 2.0T FSI motor.
Pre-Release Notes -- Please Read Carefully
This is a Pre-Release for the crank pulley (all others are in stock). Once we receive 10 paid orders, we will manufacture this part. The lead time to manufacture is 3 weeks once we receive the 10th order. If we do not ever get to 10 orders in a timely manner, we will refund all existing orders. You can check the status of the Pre-Order by calling or emailing us anytime.
Old 12-23-2016, 05:34 AM
  #15
Former Vendor
GruvenParts Billet R32/TT Adjustable Rear Swaybar Endlinks !
Got a lowered TT MK1 or R32 MKIV ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the sway bar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the sway bar end links but GruvenParts.com has you covered!
We’re proud to release these adjustable rear stabilizer bar end links with FORGED high strength steel lower bushing ends with rolled (not cut!) threads, and high strength fully sealed upper tie rod ends. The center bodies are custom machined from STAINLESS hex in house and then powder coated beautiful gloss black or Bilstein jazz blue to match our Adjustable Rear Control Arms and our Adjustable Front Sway Bar End Links.
These come ready to install and are pre-greased with special polyurethane grease and include a new lock nut on the top joint. Please re-use your existing lower OEM bolt when installing these adjustable units.
These are sold in sets of 2, enough for 1 vehicle.
This product fits Audi TT (2001-2006), Audi A3/S3, VW MKIV R32 (2004), Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0505466B.
Save Big $ when buying these in conjunction with our Adjustable Rear Control Arms and our Adjustable Front Swaybar End Links
Old 01-02-2017, 08:07 PM
  #16
Former Vendor
TT/R32 Rear Adjustable Control Arms
Click on the picture to visit our product page for up to date pricing info.
Poly Ends Now With Relocated Zirc Fittings for Easier Access !
Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered.
The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
Choose from a zero deflection high radial load PTFE lined inboard spherical joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the spherical joint and bushings is nearly water tight!
OR
A poly bushing inboard end made from heat treated 4340 forged chromoly housing, thread in grease fitting, zinc plated steel protective sleeves, and race grade greaseable black polyurethane bushings from Energy Suspension.
You decide which set up you want ! The zero deflection spherical joints are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
All GruvenParts control arms feature the following :
Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue.
Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
***Save Big $ when buying these in conjunction with our Adjustable Rear Swaybar End Links and our Adjustable Front Swaybar End Links
...And finally...
TT/R32 Rear Adjustable Control Arm Hardware
Need to buy 1 off’s for a project? Want new/longer fasteners? Look below for the parts to get the job done!
- High radial load GENUINE FK JMX Series PTFE lined heim joint kits
- Custom 4340 Forged, Heat Treated poly bushing ends with Rolled Threads
- Racing Grade protective rubber dust boots for ¾” heim joints
- Longer bolt kits - 80mm in length, grade 8.8, zinc plated
- Headlight Leveling System Bracket
Old 01-05-2017, 08:07 PM
  #17
Former Vendor
VW/Audi 1.8T/2.0T Billet Intake Links !
GruvenParts.com is proud to announce the release of these billet intake drive unit linkage arms for the VW/Audi 1.8T and 2.0T engines!.
Ours are Guaranteed for Life! - Would VW / Audi say that about theirs ??!
This GruvenParts.com billet linkage arm replaces the plastic intake manifold linkage arm found on p/n 06J-133-201-AS (06J133201AS) manifold, as well as manifold part numbers 06J-133-201-AL, 06J-133-201-G (06J133201AL, and 06J133201G).
As you already know if you are reading this, the OEM linkage arm is made from cheap plastic and becomes very brittle in the engine heat. The linkage arm socket often pops off of the ball on the manifold, rendering the variable intake manifold useless. This in turn causes a check engine light to illuminate as well as poor driveability, reduced power, and reduced fuel economy. Of course VW/Audi will not sell you *JUST* this part, you have to buy and install an entire new intake manifold to replace the cheap plastic linkage arm (with another cheap plastic linkage arm). While the manifold is pricey, the installation of the manifold and the entire manifold gasket set is where it will really cost you – most dealers and shops charge about $1,200 to remove/replace the intake manifold!
We think having to pay over $1,200 to replace a poorly designed plastic part on your intake manifold is ridiculous (and that’s putting it nicely).
GruvenParts.com is now producing these linkage arms the way VW/Audi should have: from a solid chunk of 6061-T651 Aircraft Grade Aluminum on a 4 axis CNC milling center. Ours come with a special Delrin insert installed into the machined socket to precisely mate with the ball on the intake manifold. This provides excellent lubrication and unmatched strength. Did we mention Ours are Guaranteed for Life!
This part can be installed with the manifold on the engine. Unclip the 2 actuator halves and remove the long spring and rubber diaphragm within the actuator. Unclip the useless plastic linkage arm from the manifold ball (if it hasn’t done that on its own already). Reinstall the rubber diaphragm onto our billet link arm, slide it thru the actuator, then firmly snap it onto the ball. Replace the spring and snap the actuator halves together. This should take 10 minutes, and you can do this yourself – no need for $1,000 in labor to replace a whole manifold!
You asked us for it and we listened. Another great billet replacement part to rid your VW/Audi of the weak plastic parts!
Applications:
Volkswagen : Beetle, EOS, CC, Golf and Jetta V and VI, Passat B6, and Tiguan 1 and 2 with the 1.8T or 2.0T engine w/ intake manifold p/n 06J-133-201-AS (06J133201AS), 06J-133-201-AL (06J133201AL), or 06J-133-201-G (06J133201G).
Audi :
A3, TT, TT Coupe, TT Roadster 2007-2012 with the 1.8T or 2.0T engine w/ intake manifold p/n 06J-133-201-AS (06J133201AS), 06J-133-201-AL (06J133201AL), or 06J-133-201-G (06J133201G).
Old 01-09-2017, 05:46 PM
  #18
Former Vendor
Click Here for MK5/MK6/MK7/A3 8P Adjustable Rear Tie Bars!
GruvenParts.com is proud to release our new adjustable rear tie bars for the VW MK5/MK6/MK7 and Audi A3 8P and TT MK2 chassis!
GruvenParts.com builds these adjustable tie rods the way they should be – right here in Atlanta under our close supervision in our state of the art machining center. Suspension components are far too critical to settle for Chinese made garbage with cobbled together hardware. Read how we manufacture ours below.
Replaces OEM P/N 1K0-501-529F (1K0501529F) and 1K0-501-530C (1K0501530C) or equivalent.
These tie rods are the result of our experience designing and developing suspension components used in race environments. These are sold in sets of 2 (enough for 1 vehicle) and feature precision milled 4340 steel alloy center sections which are powder coated in Bilstein jazz blue or gloss black. They are rated at over 200 ksi ultimate tensile strength. Each center body has distinct adjustment flats which are positioned for easy access allowing you to lengthen or shorten the bar while installed on the vehicle.
On the inboard end we install a custom FORGED zinc plated steel poly end with specially formulated racing poly bushings. These are not cut rate tubes welded onto threaded studs that will break in short order. Our custom forged poly ends also feature screw in grease fittings (NOT press in), and zinc plated steel sleeves with outer protective hat area to protect the poly bushing. The threads on our forged fittings are also ROLLED as opposed to lower strength cut threads. If you are looking for a poly end, this one is the ULTIMATE!
Outboard, we install GENUINE FK JMX Series zero deflection high radial load PTFE lined spherical joints with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the spherical joint and bushings is nearly water tight. This set up is preferred by racers or those who are looking for the highest level of performance.
Note : If you prefer a spherical end on the inboard side too, just ask !
Please compare these aspects when considering upgrading your non-adjustable tie rod ends to adjustable versions. Flaky vendors who build their parts in China will sell you cut-rate parts that are CRITICAL to your safety and to the safety of others around you! Don’t make the mistake of skimping out on suspension components!
This product replaces OEM P/N 1K0-501-529F (1K0501529F) and 1K0-501-530C (1K0501530C) or equivalent on the following vehicles :
2006-2009 Audi A3
2006-2009 Audi A3 Quattro
2008 Audi TT
2008-2009 Audi TT Quattro
2009-2015 Volkswagen CC
2007-2010 Volkswagen EOS
2006-2010 Volkswagen Golf (Mk5) GTI
2006-2009 Volkswagen Golf (Mk5) Rabbit
2004 Volkswagen Golf (Mk4) R32
2008 Volkswagen Golf (Mk5) R32
2005-210 Volkswagen Jetta (Mk5)
2006-2010 Volkswagen Passat (B6)
2009-2015 Volkswagen Tiguan
Don’t forget to also check out our adjustable front swaybar end links for these vehicles!
GruvenParts Billet MK5 MK6 B7 R32/TT Adjustable Front Swaybar Endlinks !
Old 01-12-2017, 07:06 PM
  #19
Former Vendor
OR
...And finally...
Old 01-16-2017, 06:43 PM
  #20
Former Vendor
GruvenParts.com is happy to release these Billet Front Adjustable Swaybar End Link sets to replace OEM P/N's 1K0-411-315R, 1K0-411-315B, 1K0-411-315D, 1K0-411-315J, 1K0-411-315K, 1K0-411-315N, 1K0-411 315P (1K0411315R, 1K0411315B, 1K0411315D, 1K0411315J, 1K0411315K, 1K0411315N, 1K0411315P) for the Audi A3/S3/RS3 (8P and 8V)TT/TTS/TTRS (8J) MK2 and VW MK5 R32, Golf/Jetta MK5/MK6, Passat B7, Eos MKV/MKVI, and Tiguan 1 and 2.
We start with a center body made from 303 Stainless Steel hex bar to replace the flimsy non-adjustable OEM spaghetti links. We then add super strong 6,000 lbs radial load capacity THK sealed ball joints with a proprietary PEEK liner on either end to provide many years of noise free operation. The THK ball joints have a built in dust boot to seal out the elements and do not require any maintenance. These linkages will not deflect under the hardest track corners and will provide the most accurate handling.
These THK ends are NOT SIMPLY SPHERICAL ENDS. These are tuned specifically for high vibrations found in swaybar end links using a proprietary PEEK liner not found in lessor ball joints.
All center sections are powder coated with a thick layer of either Gloss Black or Bilstein Jazz Blue - please choose during check out. Our design allows simple and quick adjustment on the car. Simply loosen the jam nuts at either end and spin the center body portion to lengthen or shorten, then retighten the jam nuts. This adjustable design will provide +/- 1 inch of adjustment on the car, which is enough to handle all lowered (or raised) set ups. You want the stabilizer bar end links to be as vertical as possible, perpendicular to the swaybar itself to avoid any loading in the fwd/aft direction.
Applications :
This product comes as a set of 2 adjustable end links and replaces OEM P/N's 1K0-411-315R, 1K0-411-315B, 1K0-411-315D, 1K0-411-315J, 1K0-411-315K, 1K0-411-315N, 1K0-411 315P (1K0411315R, 1K0411315B, 1K0411315D, 1K0411315J, 1K0411315K, 1K0411315N, 1K0411315P)
Audi TT/TTS/TTRS (8J) MK2
VW MK5 R32
VW Golf/Jetta MK5/MK6
VW Passat B7
VW Eos MKV/MKVI
VW Tiguan 1 and 2.
PLEASE CHECK YOUR OEM P/N BEFORE ORDERING TO ENSURE CORRECT FITMENT."
Quick Reply: :: GruvenParts.com Performance Parts for Audi !
