Navigation Installation 2008 A3 ??
I just purchased a 2008 A3 Titanium 6 Speed. The first thing I want to do is to install navigation. I have done a bit of searching and reading about doing the install and I have a few questions.
Is my 2008 'double DIN'? If not I will need to buy the adapter harness?
Is the install pretty straight forward on a 2008? Will much trim need to be removed? I looked for instructions on line but could only find instructions for older A3's and I wasn;t sure it they are the same.
Are there any units I should avoid? From what I have read I should stick with a US unit. Any units that are easier to install or ones that won't work?
Is the antenna easy to install? Where does it go?? Any instructions on this??
Anything else I should be considering or be aware of prior to buying a navigation unit???
Thanks for the help!!
I found this unit for sale. I assume it is an older unit?
4B0 035 192 P
Can anyone tell me the difference between older and newer units? What are the model number for the older and newer units??
Thanks
4B0 035 192 P
Thanks
This thread on AudiForum has what you want. Note that the 2010 RNS-E supports SDHC cards (i.e. those with capacity > 4GB), whereas the earlier ones don't.
Euro units can be converted to US & vice versa -- the process is documented at AudiForum.
Thanks for the link to the list... I am checking our converted Euro units that the selles say will support all US functions.
Are there installation instructions available for my 2008 A3? I believe I am double DIN and installation is not that hard. Any challenge to locating a spot for the antenna?
I hae searched the threads that were linked and still have a few questions:
Anyone on here who has done this installation??
Thank for the help!!
- Is my 2008 'double DIN'?
- Is the install pretty straight forward on a 2008? Will much trim need to be removed? I looked for instructions on line but could only find instructions for older A3's.
- Is the antenna easy to install? Where does it go??
The current non-Nav headunits use the same connector as the RNS-E. You may have to move a pin or two however. www.audiforum.us has conversion threads. The big gotcha is that the newer headunits don't use the diversity antenna that the RNS-E expects so your radio reception may be spotty unless you install the antanna amplifiers, etc.
Mike,
I have done a lot of searching over on that forum and still cannot find instructions on the installation of navigation on my model year.
This is the first that I have heard about the radio issues.
Thanks
If I install a 2008 RNS-E into my A3 there should be no radio issues, correct?
Thanks
