Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Powered Antennas
Old 05-26-2004, 04:29 AM
New Member
FactionOne's Avatar
Default Powered Antennas
Hi folks,
I'm here again with questions about ICE, and specifically powered antennas.
Because Audis are so damn good, and their windscreen-wipers are no exception to this, I'm unable to mount the glassmount DAB antenna which came with my DAB-54 (unless I put it in a corner (which is not really an option), because they sweep so far up the centre of the screen.
This has turned out to be a bit of a blessing in disguise, becuase it's pushed me towards upgrading the antenna to the roof-mount combined AM/FM/DAB antenna which is available from Blaupunkt - this is I suppose going to be better in the long run because it not only fits properly, but will help keep my A3's looks unspoiled (by having one antenna in the factory location, which looks almost identical to the OE part) - also it'll give better reception, because it's an active antenna...
I've seen a lot of talk on Forums on various sites about people having active antennas in their A3s from the factory, and having to get all manner of bits and bobs to use them properly on aftermarket head units.
I can't find anything but a standard antenna plug coming into the centre console of my A3, which didn't pose a problem up to now...
I'm going to replace the Audi AM/FM antenna, and run a fresh SMB cable for DAB. The new antenna is amplified though, and requires power... But I'm wondering if anyone knows how likely it is that I'll find power going to my existing antenna, and if so, how likely it is that its connection will be compatible with the new one.
Any clues to what feeds/connectors for power/signal I'm liable to find under the Audi OE antenna would be really really really gratefully received
Many thanks again for all your help guys,
Rob.
PS. Here's a picture of the female power-in block on the bottom of my new antenna for your reference (apologies for the low quality, had to take it on my fone!)
<img src="http://homepages.gotadsl.co.uk/~boltonr/a3/install/antenna-power.jpg">
Old 06-04-2004, 12:38 PM
MacSub's Avatar
Default It is powered but by the core running through the coax
I think you'll need to run a separate 12v feed from the HU to the new aerial, as although there are adapters for aftermarket HU to power the OEM antenna in this way I doubt the all in one antenna is designed to work in this unconventional way.
zoepup
11
03-30-2018 01:28 AM
Audi'sRevenge
Telematics Discussion
11-04-2008 11:20 AM
JD797
11
10-16-2006 05:23 AM
HipsTTR
16
08-09-2002 05:59 AM
Audi RSF1
06-03-2002 06:42 PM
Quick Reply: Powered Antennas
