question re: mechatronics replacement
On behalf of those of us that have had, are having or will have the mechatronics unit replaced, what are the odds that it will be prone to future failures?
Once replace, will the tranny be as good as new, or will we be likely to see this problem reoccur in the future?
thanks
thanks
It might be easier to predict the winning lottery numbers.
As I've said before, these are machines. Machines will break. You get them repaired (or not) and get on with your life. It's not worth fretting over whether your transmission will ever fail again nor is it possible to compute the odds of your transmission failing again.
90mtl
08-02-2007 08:32 AM
Nick Gustas
08-29-2000 05:31 AM
