widshield washer not working?
got no juice from either front or rear windshied washers. the reservoir is full (with winter fluid), and I can hear the pump each time I press the control, but nothing squirts out. any thoughts?
thanks |
gotta be a hose came loose
Sounds like a personal problem. Better see the doc. ;)
I had one that was clogged, dealer had to order a part and put in the new one.
Re: widshield washer working again...
Me thinks it was somehow clogged and cleared by magic? or else the milder temperature melted a frozen line. Reservoir was filled by the dealer at last service...maybe they used crappy juice? Anyway, thanks for the replies.
yeah, must have been a clog before the line forks, preventing fluid from going to either window
Had it been dipping into freezing temps where you live? If so, check to be sure you've got a winterized mix of washer fluid.
