2014 A3 (8V) 1.8TFSI EPC Turbo problems?
Hi All, PLEASE HELP!
I am in need of some SERIOUS advise. I've taken my car to a number or garages and nobody seems to know what the problem is with my car. The last mechanic seemed to think its an electrical issue and told me to go see a auto electrician but I'm not convinced.
DESCRIPTION:
When I turn the ignition (sometimes I have to turn the car on for it to happen) I hear a mechanical grating noise which after inspecting the logs seems to be the Turbo actuator. After turning the car on and hearing this noise the EPC light comes on and the car doesn't hold boost properly (or is in limp mode). Sometimes, specifically when the car is warm the startup noise doesnt occur and the car runs fine for a minute or two then at about 1600rpm I hear some resistance and the EPC light comes back and the car is again in limp mode.
LAST NIGHTS LOG:
Monday,06,May,2019,19:56:23:27541
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
Ross-Tech: Home
VIN: WAUZZZ8VXEA038626 License Plate: CA562747
Mileage: 124097km-77110mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8VXEA038626 Mileage: 124097km-77110miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJSA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 B HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0002
Revision: --H09---
Coding: 0A1900122404010B2000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM18TFS0218V0906264B 001002
ROD: EV_ECM18TFS0218V0906264B.rod
VCID: 3B754468B20E359C0D-806E
4 Faults Found:
15470 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 6
Mileage: 124062 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 89 °C
Intake air temperature: 54 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.773 V
Unlearning counter according OBD: 40
Engine: operating status: ES
Engine temp. management actuator: raw value: 1535
Engine temperature management actuator: stop open: 139
Engine temperature management actuator: after-run stop: 3978
RVC_SP: 88.75 °
RVC_AV: 92.72 °
RVCPWM: 28.473 %
16986 - Insufficient Engine Cooling / Coolant Flow
P00B7 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124077 km
Date: 2019.05.04
Time: 18:29:27
Engine speed: 836.75 /min
Normed load value: 7.5 %
Vehicle speed: 2 km/h
Coolant temperature: 100 °C
Intake air temperature: 48 °C
Voltage terminal 30: 14.277 V
Engine: operating status: IS
Engine temp. management actuator: raw value: 1946
Engine temperature management actuator: stop open: 145
Engine temperature management actuator: after-run stop: 3948
RVC_SP: 124.75 °
RVC_AV: 120.75 °
RVCPWM: -29.236 %
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124034 km
Date: 2019.05.04
Time: 16:02:05
Engine speed: 159.00 /min
Coolant temperature: 31 °C
Intake air temperature: 31 °C
Voltage terminal 30: 10.175 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
Charge air pressure control valve uncond voltage sensor-VP_BPA[0]: 4.4922 V
Charge air pressure control valve position: target value-POSN_SP_BPA[0]: -0.00 %
Charge air pressure control valve position: actual value-POSN_BPA[0]: -0.067 %
Charge air pressure control valve activation pulse duty factor-PWM_BPA[0]: -27.512 %
Charge air pressure control valve voltage: position closed-VP_BPA_AD_BOL[0]: 4.4873 V
STATE_BPA[0]: AD
15202 - Actuator Module for Turbocharger 1
P00AF 00 [109] - Stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 124020 km
Date: 2019.05.04
Time: 11:48:40
Engine speed: 1935.50 /min
Normed load value: 18.4 %
Vehicle speed: 16 km/h
Coolant temperature: 99 °C
Intake air temperature: 46 °C
Voltage terminal 30: 14.238 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve uncond voltage sensor-VP_BPA[0]: 4.3994 V
Charge air pressure control valve position: target value-POSN_SP_BPA[0]: 95.00 %
Charge air pressure control valve position: actual value-POSN_BPA[0]: 2.197 %
Charge air pressure control valve activation pulse duty factor-PWM_BPA[0]: 99.997 %
Charge air pressure control valve voltage: position closed-VP_BPA_AD_BOL[0]: 4.4824 V
STATE_BPA[0]: OPM
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 615830000004B1
Coding: 12F18AA234232A74017D060241C92948512C5480608294F400 4100080508
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BF58468F28EF59C4D-802E
1 Fault Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 123872 km
Date: 2019.05.02
Time: 00:01:51
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H13 0031
Revision: 20023000 Serial number: 00000000119294
Coding: 03100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 6FEDA038B6F6993CF1-803A
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: F4598AB6000000000001
No fault code found.
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0137
Serial number: 00011319700611
Coding: 07040A42C24122FD03844004B30C07A8000000000000000000 0000000000
Shop #: WSC 60918 002 1048576
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 000FF3849B68964418-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130630 041 0580
Serial number: 130708130516
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21554257
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Component: E1 - LDS MQB H05 0032
Serial number: 26 05 2013 00000422
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY13175155U
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000027489649
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 163
Reset counter: 130
Mileage: 122928 km
Date: 2019.04.09
Time: 21:40:32
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R02F64
Coding: 98CCC000000000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4B9514A8E2AE851CBD-801E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 001 207 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000648415D0Q
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 207 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000548415D0Q
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 307 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502AB107DB5550CG
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 307 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502A3107DB53B326
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 806 13
Component: FrontSensor_D 001 6149
Serial number: 3556502B11074465D25%
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 15071304220307
Coding: 8418
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 77FD9858CEA6D1FC29-8022
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 870 G HW: 8V0 920 870 G
Component: KOMBI H03 2211
Coding: 278409002A8000080100A800000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
VCID: 3F8D3078A61629BC21-806A
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000771660
Coding: 030100042B085A005B000248080B0000000100000000000000 0000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009_VW37.rod
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 06 07 2013 C0297536
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051717820
1 Fault Found:
66565 - Diagnostic Databus
U1202 00 [008] - Malfunction
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 111
Mileage: 123792 km
Date: 2019.04.29
Time: 18:08:19
Supply voltage: Terminal 30: 12.0 V
Terminal 15: On
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 11071301100117
Coding: 001C8E204101040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D714A70AC1A3BAC33-8068
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 01071302090152
Coding: 001C86204101040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3E734D7CA11C20B42A-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 019E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: 75E19250D4AAA3EC3B-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 840 A HW: 8V0 035 840
Component: MU-S--ER 040 0370
Serial number: A3E01307131483
Coding: 01730300FF0A000011110001000A00002F0001060100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 33656C489A5EFDDCD5-8066
Display unit 1 for multimedia system:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H48 0013
Serial number: AUZ8Z9DG601LBU
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000029051300020020
1 Fault Found:
6179 - Display Module 1 for Multimedia System
B1297 F6 [008] - Cable for Video Signal; Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 19
Reset counter: 130
Mileage: 122522 km
Date: 2019.04.03
Time: 19:27:54
Voltage terminal 30: 12.2 V
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 29061303110082
Coding: 000C86204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 41893680D0E25F4C57-8014
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 010 0006
Serial number: 29061304080082
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 03:23)--------------------------
QUESTION:
It is possible that there is a problem elsewhere in the car that is affecting the turbo actuator? Such as a bad lambda sensor (o2) or a clogged catalytic converter.
Please note I am not a mechanic just another poor man with a broken Audi :P
Thanks in advance
DESCRIPTION:
LAST NIGHTS LOG:
Ross-Tech: Home
Revision: --H09---
4 Faults Found:
P00B7 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 124062 km
Date: 2000.00.00
Time: 00:00:00
RVC_SP: 88.75 °
RVC_AV: 92.72 °
RVCPWM: 28.473 %
P00B7 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124077 km
Date: 2019.05.04
Time: 18:29:27
RVC_SP: 124.75 °
RVC_AV: 120.75 °
RVCPWM: -29.236 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 124034 km
Date: 2019.05.04
Time: 16:02:05
STATE_BPA[0]: AD
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 124020 km
Date: 2019.05.04
Time: 11:48:40
STATE_BPA[0]: OPM
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 123872 km
Date: 2019.05.02
Time: 00:01:51
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 130
Mileage: 122928 km
Date: 2019.04.09
Time: 21:40:32
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 8418
Alternator:
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 111
Mileage: 123792 km
Date: 2019.04.29
Time: 18:08:19
Terminal 15: On
Coding: 81
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 19
Reset counter: 130
Mileage: 122522 km
Date: 2019.04.03
Time: 19:27:54
QUESTION:
Thanks in advance
mAd1(gt3071r)
09-08-2005 05:44 PM
Noise when car idles back down to normal.......kinda like turbo spooling down but a annoying chatter
MXSX19
06-17-2002 05:44 AM
mm
33
09-13-2001 09:08 AM
